VT365 engine
Old Feb 26, 2014 | 05:41 PM
TJK1's Avatar
TJK1
VT365 engine
I've come across a 2004 VT365 engine for sale. I was thinking about buying it to keep a few of the things on it as spares and part out the rest of it. Guy is asking 550. My questions are do you guys think its worth it since it is a little different than the 6.0? and are a good amount of the parts compatible with the 6.0. Like the injectors, turbo, sensors?
Thanks for any thoughts
Old Feb 26, 2014 | 05:52 PM
npccpartsman's Avatar
npccpartsman
Virtually the same engine. The thing you have to be careful with parts wise is that the pistons in that time frame can be different and glow plugs different lengths. That's a cheap price if the internals are good.
Old Feb 26, 2014 | 06:01 PM
TJK1's Avatar
TJK1
Does the ICP in the valve cover mean a late 04 with these engines as well? If so, mine is also a late 04 so I was thinking most things would be interchangeable. Right?
Old Feb 26, 2014 | 06:05 PM
npccpartsman
Exactly right. Does the HPOP have a cast iron or aluminum cover? Aluminum would indicate an 05 and up. Not really a problem either.
Old Feb 26, 2014 | 06:57 PM
dannyboy950's Avatar
dannyboy950
Doesn't the International use a fuel pump mounted behind the powersteering pump? May be I am thinking of a different engine.
Old Feb 26, 2014 | 07:07 PM
cheezit's Avatar
cheezit
Fuel pump on 650 and 750 is part of the ps pump.
The injectors have different part numbers if ordering them threw ford.
Fefanatic
Sep 2, 2017 09:46 PM
dgulledge
Feb 1, 2015 07:27 AM
run6.0run
Apr 26, 2013 03:39 AM
Iggy811
Sep 9, 2012 07:17 PM
MucksCo
Apr 21, 2012 06:32 PM
