Too much wheel camber- 1996 F250 4x4 7.5L
So I have an issue with having too much wheel camber on the passenger side of my truck, I have replaced the wheel bearings, ball joints, and pivot pushing. Someone suggested that it may be the leaf spring is too weak. Any suggestions of what I should check??
Springs do sack out eventually. While you could install alignment bushings in the upper ball joint to compensate, it may be wiser to replace sacked springs. The spring and shackle bushings may be shot as well. If you do replace the springs, the truck may need an alignment anyway, but you won't know until after install. You might try contacting ATS Springs, they're a forum sponsor and they know springs, often chiming in on posts like your's with advice. They would be able to help you figure what you need in terms of spring rate for your application and use.
Powerstroke1995
02-24-2014 12:50 PM
rm.lydon08
05-15-2012 09:53 AM
jackslater
09-15-2010 06:58 PM
Ingy
03-31-2006 08:39 PM
