HFCM/filter work, now no start
Old Feb 18, 2014 | 10:23 AM
  #31
mustang_309's Avatar
mustang_309
Originally Posted by bbender85
so adding a 5 gallon can of fuel was a bust. fuel pump was securely plugged in an verified to be running.
i got under and opened the water drain valve and we put some compressed air to the fill neck and got fuel to run out the water drain. cool. closed that and went up to the bowl and added more air to the fill neck. a few bubbles in the bowl and then we had a good flow of fuel coming up the bowl. now we're getting somewhere. so we stop putting air to it; thats when i watched the fuel in the bowl receed. that doesn't seem right. tried to cycle the fuel pump and it wouldn't bring it back up.
so having tried two of my three tricks i had up my sleeve, i went to plan C, which was the $55 gasket kit for the HFCM manifold cover. installed it, went back up top and had my buddy cycle the fuel pump, nothing. did it again, nothing. one more time, BOOM, fuel is coming out of the bowl like oil out of Jed Clampett's swamp. i think we're getting somewhere. put the bowl cover on, cycle the pump twice, crank the engine, presto, happy 6.0l
so the HFCM gasket wasnt' sealing between the chambers it seperates. it looked a little swollen when i was dealing with it Sunday, but i thought for sure it would lay in its race when i tightened the cover... apparently not.
thanks for everyone's help!!!
Glad to see you got it rocking.
Old Jun 18, 2018 | 11:22 PM
  #32
leerobert's Avatar
leerobert
I am also having crank no start issues but I am getting obd2 p0231 low fuel pump voltage, Checked shut off switch and it lights my test light when KOEO and I know it has a integral fuel pump in the CJB but isnt there another relay and or fuse that is removable that I can check? any help is appreciated. 06 f250 sd 6.0
2001400ex
Jan 31, 2010 06:14 PM
krejci.mike
18
Oct 6, 2009 01:26 PM
NS F250
Feb 10, 2008 12:45 PM
ottr1967
Nov 23, 2006 02:02 AM
hoopstir1
Jul 20, 2006 08:28 PM
