The front under the cover ones may be a little rusty, mine were. Your rear bolts are like mine, right in the open. The left side may be a slight problem, these have nuts on the bottom and the left side is not very accessible with the front tank installed.
I took my front ones loose and jacked one front corner at a time up to remove the upper frame gusset bolts for the C6 after I installed the E4OD.
Did you have any problems with rusty bolts not wanting to come out? If so, did you use that Acetone and ATF mix to take care of them?
SVT, listen to these guys as they've done it more recently than me; I can only go by memories of ~3 years ago.
I'll take any advice I can get. I'm like a sponge at this point. Would love to see some pictures if anyone has them? I've seen other posts where they show the cab off the truck and all, but I want to see what i'm up against...first-hand ya know?
PM Gary Lewis, or start on his "Dad's Truck build" thread.
the things you want to spray/soak is the bottom side of the bolts, they thread into the metal sleeves that hold the body bushings, because you cant get to the good part to spray, because it is sandwiched between the cab and frame.
and all four of the sleeves are accessible with a breaker bar and a socket, you just need an extension for the drivers side rear one. then an impact on the top side, it is really extremely easy, you may be over thinking it, the 84 was a basket case rust wise and all 4 came off not any huge issue, we just use wd40.
if you really want any more in depth, look through both my build thread sections where we took the cabs off. also have pics of the sleeves in both of those as well. but like i said, really not hard at all. and on the 84 front ones under the cover in the floor pan, the floor and screws were so rusted i just cut the head of the screws off with a wiz wheel, and pryed the cover upwards.
If the transmission is out of the truck when you install the cab on a chassis, the transmission cross member will probably be out. You'll want to have the four bolts for the cross member gussets installed in their holes in the frame before you bolt the cab down. Those bolts are trapped in the frame by the cab floor.
very good point, we didnt run into this issue with the 84, because powertrain was already installed on the chasis, but we would have ran into it on my 97 but the uncle thought about the issue, before the cab was put on so it wasnt an issue
Big thanks man! I'm sure it'll go smoothly when the weather warms up and the ground hardens. I'm going to practice on the lifted truck first, because i'm not using that cab. Then focus the careful work on my cab, and go from there.
As long as I have the crossmember in, setting the tranny down on it won't be a big deal will it?
That wont be an issue at all, on the 84 we had the whole powertrain installed and then dropped the cab on top, waited to put the trans floor pan in until after the cab was on the frame though because we left shifters in again
