Installing cab - best way? - Ford Truck Enthusiasts Forums
Old 01-08-2018, 09:37 PM
jerry_s's Avatar
jerry_s jerry_s is offline
jerry_s is starting off with a positive reputation.
A bit ironic that currently Greg Rogers's post is about removing the cab!
Anyways, I'm at the point where I want to start putting a lot of the parts back on the chassis so I can get it to the shop to do the final parts - wiring, etc.
The cab seems like it's gonna be the hardest part. I have a lot of tools, but not many friends in the Irvine area, so any method that would require fewer people would be best!
Old 01-08-2018, 09:48 PM
jvmcc's Avatar
jvmcc jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
Four people can place a cab on a chassis, as long as that's all it is...a bare cab without doors, seats, etc. Getting the two front bolts in is a breeze. It's handy to have a couple of helpers to wiggle the cab around when you go to put the bolts through the dog bones.
Old 01-08-2018, 10:00 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I used the shop hoist for removal and installation..
Old 01-08-2018, 10:06 PM
jerry_s's Avatar
I do have a shop hoist. How did you make the wooden piece that goes in the cab and not have it tilt such that the cab just slides off?
Old 01-08-2018, 10:09 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud ofEffieTrucker has much to be proud of
I did mine the same as John. You can see my cab reinstallation starting here:
https://www.ford-trucks.com/forums/1...l#post17604981
Ignore the picture with the chains, 2x4s, and come-a-long. That was before I had an engine hoist.....and brains.
Old 01-08-2018, 10:23 PM
Posting Legend
Maybe this picture will give you a better idea , it was something I through together about an hour before I lifted the cab off the frame. This picture of course was one of the several times I had it on and off the frame. When it's lifted it stays level and balanced perfectly..
just
Old 01-08-2018, 10:30 PM
Gicknordon's Avatar
Gicknordon Gicknordon is online now
Gicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to behold
Only need two people this way, one if you want to get on and off a bunch of times.
Old 01-08-2018, 10:35 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.raytasch has a spectacular reputation.
Go back and look closely at examples of cab handling in the removal thread. It is a one man job to install the cab with an engine hoist. Just plan and go slowly.
Old 01-08-2018, 10:42 PM
Posting Legend
Quote:
I think you'd have to be careful so you don't damage your drip rails that way using slings...but you definitely have the biggest shop hoist...lol
Old 01-08-2018, 11:02 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to beholdJeff and Nicolle is a splendid one to behold
Downright SHOW-OFF!! Spoiled Kid! Geezzz...
Old 01-08-2018, 11:06 PM
Quote:
just
This looks exactly like how I did it. 4X4 across inside the cab, centered the end of the hoist until it balanced. Careful careful and worked great!
Old 01-09-2018, 12:18 PM
jerry_s's Avatar
Just a couple of questions on the image that 56Panel uploaded:
Old 01-09-2018, 12:56 PM
Quote:
Everything is connected, making it one solid rig. The flat pieces on the end are connected to the 4x4s, not only tying them together, it forms a cradle to keep the cab from sliding off the ends.
I think the metal pieces are just a couple of angles to connect the end of the hoist to the middle 4x4. John will have to answer that one.
Old 01-09-2018, 01:09 PM
Indybeer's Avatar
Indybeer Indybeer is offline
Indybeer has a great reputation on FTE.Indybeer has a great reputation on FTE.Indybeer has a great reputation on FTE.Indybeer has a great reputation on FTE.
I don't have any pics, but I used a ceiling hoist also. I used 2 4 by 4's thru the door with 2 straps between the beams and the hoist. I also used a engine leveling bar to level it front to back as I lowered it. I got the cab on by myself with no problem.
Old 01-09-2018, 01:12 PM
highdesert55's Avatar
highdesert55 highdesert55 is offline
highdesert55 has a good reputation on FTE.highdesert55 has a good reputation on FTE.
I just did mine by myself using a engine hoist through the side window and using four ratchet straps hooked to seat belt bolts in the floor. I was actually surprised how easy it was.
CMHSL Camera after the fact Jerry Weigel 2017+ Super Duty 0 01-12-2017 01:48 PM
Old truck resto guy jep New Member Introductions 2 09-19-2016 03:10 PM
pictures jerryst 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-13-2016 12:42 PM
Best place to install remote oil filter jerry_s 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-19-2016 08:36 PM
Oil indicator light and amp light Oldschool2888 1961 - 1966 F-100 & Larger F-Series Trucks 4 03-15-2016 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
