Torque Converter Talk
As for the engine, the issue is getting the throttle blades at the right spot with respect to the transfer slot in the carb. If the throttle blade is already into the transfer slot at idle you won't get the tip-in response you need to make it drive well. There's a balance between timing advance and throttle position, and we need to figure out what that engine needs. The guys are suggesting you may need to use manifold vacuum to the advance so you can back off the throttle at idle. Try that, meaning connect the advance to the right/driver's side port on the carb and back off on the idle stop screw. That may do it.
If not, it may be time to bring it to the Garagemahal - if you can get it here. You should have more vacuum with the timing you have, so we need to re-establish that your balancer is still on the mark. And then play with the vacuum advance, but only after we see what the E'brock expert dialed into your dizzy.
Explain to me why you think you should be trying anything close to "stock" settings.
Once you get the idle down, preferably 1000 or below, it should cure the dieseling problem. Then you are going to hook up the vacuum advance to the manifold vacuum, the idle will raise up again, and you will have to turn it down again. You will get that all set, and then when you put it in gear, I predict it will keep stalling on you each time you put it in gear. That's why I always run ported or timed vacuum on a automatic vehicle, and why you should just leave the vacuum on the dist unplugged till you get this thing worked out. You have got too much going on now, at least leave one thing out so you can worry about it later.
As for advance, initial shouldn't be more than 14 or you'll probably have starting problems. And idle RPM can't be 1500 or it'll never die. I think you are close but have the details wrong.
Dieseling is the death rattle of a spark engine.
Hot spots kill spark engines no matter if it diesels or not, they cause pre-ignition, knocking, spark knock, dieseling, etc. Whatever you call it or whatever it actually is, it's a very bad thing.
Something more serious then ignition timing or too fast idle of an idle is wrong with this engine if it's brand new and dieseling.
See what Dave said above...
Vacuum advance (ported or manifold) is just another way of broadening the optimal operating range.
-Beyond the centrifugal ignition advance curve-
Bruno is using DSII with ignition retard.
Whatever number he has at idle is really 5-6*(?) less while cranking.
The tuning instructions that come with the Crane vacuum advance spell out how to do it.
It needs to be approached step by step.
Initial (static)
Centrifugal (curve and limit)
Vacuum (point at which it comes in and how much)
He had 'Edelbrock Expert' set #2 but hasn't settled #1 yet.
I'm not going to argue this with you, more then likely knowing FTE you'll just ban me for it. I just don't want to see poor Bruno end up with a 351ci paper weight cause of the poor advice he gets here.
Dave I've read some pretty smart stuff from you, clearly you know your Fords, but this is bad advice, I can't read it and not dispute it.
Bruno - It sounds to me like your in over your head, please take your time, think this out, go slow and maybe find someone local to help you out. In general you need to get a good base setup at this point so you can deal with the dieseling and break in your new engine without causing damage. Double check everything before you start it again, didn't you mention a valve adjustment issue? This might be a good place to start.
Tell me about this engine or link to where this info is?
Compression ratio
Heads
Who did the work
etc.
If you start it again, yes eventually you will need to deal with timing issues but please just keep it simple for now. Leave the vacuum unplugged, set it at 14 at idle, make sure the RPM advance isn't advancing at idle and get a real good carb adjustment in. Making sure the engine doesn't destroy itself is more important then anything else, the rest can be dealt with later.
Compression ratio
Heads
Who did the work
etc.
Back to the subject, BruteFord don't back out now and tell him to get help somewhere else. I am going to flame you a little bit here, if you know how his engine should be properly setup, guide him through it. I can state my opinion on what he should do, you and others can state theirs and give advice, he can try it, if it doesn't work he can try something else.
Keep at it, we can all learn something here I believe.
I'll try but Bruno has to provide more, I need specs, compression, heads, who did what work, plugs, carb, a video, pictures, etc. My one voice being contradicted by so many others isn't going to do much good. And in many ways it may be just plain too late.
And no it's not as simple as he can try, if it doesn't work he can try something else. If he does or has done the wrong thing the damage is done and that is it. The first fire and few hours of a new engine are critical, there is no coming back from mistakes made then.
Shoot look at some of these guys on TV, for example I like Fast'n'Loud, I find it very entertaining but even the so called "master mechanic" Aaron doesn't know engines very well. I've cringed as I watched him and his cohorts ruin a new engine.
