All you need is a dizzy with an adjustable vacuum advance, a 10L/12L slot, and starts advancing between say 1000-1100 RPM. Should be able to get it to idle right about 900-1000 in park 800-900 in gear.
Plug vacuum advance to manifold vacuum, adjust the vacuum can, timing, and carb so that it idles in gear with the vacuum advance barely full on, with timing where it makes peak vacuum(mid-high 20s), and at 800-900 RPM. When put in park, vacuum goes up and should still be under 1000 RPM so timing shouldn't change, and at idle that low the stock converter should only drag a little so the RPM will only climb a little. When shut off vacuum goes to 0, so starting timing will be in low teens so easy to start.
EDIT biggest variation here that is hard to control for is the amount of vacuum advance, it's very hard to limit it on a DSII dizzy.
Yup, though last time I tried to buy one I couldn't get it, that might be fixed now. However there are some other aftermarket DSII adjustable vacuum advances available.
So anyways, before the wifey/office IT person pulled the plug on my web service in order to install the router and server I was going to say" IMO the cam isnt that radical because Gary and I put a degree wheel on it and there wasnt a need for an adjustable timing set". Meaning that the straight up position on the double roller set was just fine.
I was going to call ACC and get their 0.02. I am sure they will try to sell me a TC, but just curios as to what they say. I was eyeing a Night Stalker that is supposed to stall around 1800 rpm. Seemed like it was around $200-$250.
Now you guys have me looking at for an adjustable vacuum advance unit for it.
Now you guys have looking at for an adjustable vacuum advance unit for it.
You may have one already and not know it, many aftermarket distributors come with an adjustable advance and they don't look any different. Find a 3/32 allen wrench, stick it in the hose nipple, and see if it grabs something.
I have a stock Motorcraft vacuum advance and it's adjustable. Says Motorcraft right on it. That's another thing to look out for.
Hard to say, I think the one on my truck is a standard products brand and the part number sounds right. But the picture is wrong, I saved the lid to the box mine came in to save the part # but it's been a couple years, honestly I'm not sure I can find it again.
I am hoping to get on the DSII swap this weekend, but I am whooped right now. I have been doing a 3 person repair job by myself all week because I have too much stuff going at one time.
Hopefully a good nights sleep tomorrow night will put in a better mood. However, I will be doing something to the Bronco this weekend.
Back when I was trying to tune the timing on my truck, I contacted Crane before dropping money on a new advance unit.. since my old Motorcraft one was adjustable. Their unit still adds 24 degrees of advance.
This in my mind is the single hardest part of tuning vacuum advance. For a use like I suggest for Bruno 24 is too much and it's a very hard mod to make an adjustable limiter in a DSII unlike a GM dizzy. We need a list of available vacuum advance canisters and how much they advance, but I have yet to find one. To me this is the only real advantage to aftermarket distributors like MSD, you can get a Ford dizzy with GM style advance but Ford pickup and Ford big cap.
