Steering column
Old Feb 1, 2014 | 10:12 PM
Truck Guy99's Avatar
Truck Guy99
Steering column
Where can I get a column for my 88 F350? I have trolled Craigslist and ebay for 2 months, called and searched countless junkyards, searched Google, parts geek, rockauto, and LMC with no results. I would really appreciate any help in locating one. Are there any websites that sell entire columns?
Old Feb 1, 2014 | 10:29 PM
Evan_P's Avatar
Evan_P
Ford Auto Tilt Steering Column | eBay
1980 1991 Ford F150 F250 F350 Steering Column Automatic Tilt Rebuilt | eBay
80 91 Ford Pickup Truck F150 F250 Bronco Rebuilt Auto Non Tilt Steering Column | eBay
As for Craigslist, don't search for the column itself, look for people parting out trucks. I know you can get one from a F150, F250, F350 or Bronco from 87-91. I believe, might be wrong, that 80-86 are the same column as well. Just make sure you get one for an auto.
Old Feb 1, 2014 | 10:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What's wrong with the original column? Most of the parts are available to repair it.
You need to know exactly which column you have and the years it fits...before looking for a replacement.
A/T different than M/T, with tilt steering wheel different than without.
1978/91 F100/350, Bronco & Econoline tilt wheel operated by pressing the T/S handle forward.
Old Feb 1, 2014 | 11:48 PM
Truck Guy99
The column has several broken pieces in it, a spring and a few other parts fell out the bottom of it a few days ago, the lock tumbler is missing its key, and the plastic on the column is gone. It's beyond repair.
A/T with tilt
My 350 has the tilt column and the T/S is pushed back to tilt. I was also told I can't use one from a truck with an overdrive transmission because mine is non-OD and this would cause the shift linkage not line up or connect. Is this correct?
Answers and questions in bold
Old Feb 2, 2014 | 12:36 AM
Island Time's Avatar
Island Time
Minor thread hijack here. Can you upgrade a non tilt truck to tilt with a new column? I would think the function is specific to the upper part of the column, but maybe it's more complex than that.
Old Feb 2, 2014 | 07:14 AM
whalebus2112's Avatar
whalebus2112
I have one out of a 95 f350. If it will work let me know, I will sell it cheap enough
Old Feb 2, 2014 | 08:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
completely different animal and will not work in the 88
Old Feb 2, 2014 | 01:14 PM
Bright Regatte Blue's Avatar
Bright Regatte Blue
In addition, the '95 has a multi-function lever (windshield wipers/washer and dip switch, in addition to the turn signals), whereas the '88 just had a turn signal lever. Never mind that the '95 is an airbag truck...
Old Feb 2, 2014 | 01:48 PM
Monteg0's Avatar
Monteg0
Check car-part.com
Old Feb 2, 2014 | 02:20 PM
tjc transport
i ain't rite
car part has a few listed in texas, but they are crazy high priced, and all are listed as parts only
Old Feb 2, 2014 | 02:59 PM
Monteg0's Avatar
Monteg0
I count 13 usable ones between $100-$125 including one in OK (and then a bunch of junk and the obligitory massively overpriced parts). i think OP is in TX. so that's not too far. Id still try and find a local truck sitting in a field somewhere myself though first.
Old Feb 3, 2014 | 08:36 AM
txnightster's Avatar
txnightster
I bought one from these guys. Yes it was expensive but so is my time trolling thru junkyards.
It will come with new keys and is completely rebuilt. As simple as plug and play.
Henrys Locksmith
Good Luck!
chillman88
19
Jan 21, 2017 09:58 AM
Cg willie Willie
Jan 18, 2017 09:14 PM
blackjack33
Sep 13, 2016 03:58 PM
Boba Fett
Jan 18, 2013 08:49 PM
LIVE_WIRE
Aug 16, 2012 02:08 PM
