Anybody know what is the interchange for a column collar on a 78-78 truck with a floor shifted manual transmission? I have always had a floor mounted shifter in my truck with a manual shift column..... finally want to change that out....
You have a column that originally came with an A/T or 3 speed, so...you want the column extension that takes the place of the shift collar w/a 4 speed, correct?
If so, the tilt steering column extension is different than the non tilt steering column extension.
Does your column have a tilt wheel? Tilt wheel works via the T/S lever by pressing it forward.
It a non tilt column... I am geussing three speed... The truck had an srod by the time i got it.... Which the way the floor was setup was the factory trans.
D8TZ-3790-A .. Steering Column Extension ~ Use without Tilt Wheel / Obsolete
