OBDII Code P1405
Old Jun 28, 2003 | 03:03 PM
Dougwhite's Avatar
Dougwhite
OBDII Code P1405
My check engine light came on recently and I had the code checked. It's a P1405: DPFE Sensor Upstream Hose off or Plugged.
I think I've identified the Differential Pressure sensor, but all of the hoses seem good and clear to me.
Any ideas?
Old Jul 4, 2003 | 07:26 AM
Rockledge's Avatar
Rockledge
OBDII Code P1405
Hi and welcome to FTE!
If you've located the DPFE and all the hoses and stuff look OK, then you probably have a bad DPFE. They are known to fail and are easy to replace.
Old Jul 4, 2003 | 05:25 PM
Rockledge's Avatar
Rockledge
OBDII Code P1405
You did not say what truck you have or what year it is.
FWIW, here is a picture of the DPFE on my '98 4.0L Ranger:
Old Mar 21, 2009 | 09:39 PM
compnecessity's Avatar
compnecessity
craked house P1405
I had the same code this week. The hose on the right side was cracked. I replaced both of them. Auto Zone didn't have anything close to the size of house, but Oreilly's did. The right side house was stuck on really good. Had to take a razor blade to get off the pieces stuck on the the bottom metal port.
Old Feb 11, 2010 | 11:34 AM
crscrkranger's Avatar
crscrkranger
1998 4.0L, ranger 4x4
Just had the code come in on my 98 Ranger 4x4. While it appears the hose connector has been bad for some time, code just appeared. Hose cracked and completely disconnected. Also, from the appearance of the hose very hot gas had been through it and exited through the crack in the hardened and brittle hose. The gas melted the connector off and melted the plastic hose protector for the AC line nearby.
Since it just came in, what's it for? Truck runs great, Gas mileage may suffer slightly but could be from other reasons.
BTW, great photo of sensor and hoses.
Old Feb 11, 2010 | 11:51 AM
Rockledge's Avatar
Rockledge
Welcome aboard. Check out: The Ford DPFE/EGR System
Nomadic Van
3.8 & 4.2L V6
Jul 19, 2016 10:02 PM
Kevin Beard
Sep 12, 2015 12:52 PM
Plowboy34
1983 - 2012 Ranger & B-Series
Jul 22, 2012 01:40 PM
ExpySport
May 29, 2009 03:25 PM
proudfrog
Feb 10, 2009 12:50 PM
