95 f150 multifunction switch
Old Jan 29, 2014 | 01:22 PM
fordka's Avatar
fordka
How do i change my multifunction switch in my 95 f150. I think mine has gone bad and i have another hope it works tho. Im not sure if mine is bad or something else is wrong but who knows till i try another
Old Jan 29, 2014 | 01:48 PM
spacegrass's Avatar
spacegrass
Very easy, search for more details including probably pictures, but for simplicity:
Remove plastic top and bottom covers surrounding the switch and the column via the screws underneath (I think there's 2, but I may be wrong).
Remove old switch via 2 torx screws holding it to the column.
Disconnect wiring harness.
Installation is reverse of the removal.
Old Jan 29, 2014 | 03:25 PM
rla2005's Avatar
rla2005
Your 1995 F150 will most likely have an airbag. I highly suggest you disconnect the battery then wait for 15 minutes before messing around with the steering column.
fordinmudd
Mar 4, 2011 01:36 AM
sonex122
Electrical Systems/Wiring
Nov 28, 2010 09:31 AM
lt281
Nov 14, 2008 04:33 PM
dfishrmn88
1997 - 2003 F150
Mar 2, 2006 04:50 PM
John Thomas II
Oct 11, 2005 08:03 PM
