HElP! 03 Expl Multi function switch
Old Nov 26, 2010 | 10:43 AM
sonex122's Avatar
sonex122
I tried for hours to install a new flasher relay/multi-funtion switch with no success. What's the easiest way to acces the relay panel so I can see the top to install the switch. Thanks
Old Nov 27, 2010 | 10:10 AM
Franklin2's Avatar
Franklin2
To remove the multi-function switch on a 03 explorer remove these pieces in this order;
1 391727-S436 Steering column opening cover screws
2 04459 Steering column opening cover
3 W705314-S424 Column shroud screws
4 3530 Steering column lower shroud
5 W705314-S424 Column shroud screw
6 3530 Steering column upper shroud
Removal note;Remove the upper steering column shroud.
Release the retaining clips and rotate the upper steering column trim panel out of the instrument panel.
Remove the upper steering column shroud hard shell.
7 — Ignition switch electrical connector
8 11572 Ignition switch
Removal Note;Release the two locking tabs and remove the switch
9 — Spring (part of 11572)
10 W706952-S424 Multifunction switch screw
Removal Note;Remove the screw, push the release tab and raise the switch.
11 — Multifunction switch electrical connector
12 — Multifunction switch electrical connector
13 — Multifunction switch electrical connector
14 3K359 Multifunction switch
Old Nov 28, 2010 | 09:31 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Don't forget to pull the negative (ground) cable from the battery BEFORE you start!
PStruwing
15
Nov 9, 2015 06:17 PM
efrontz0816
Apr 26, 2014 04:33 PM
canman533
1983 - 2012 Ranger & B-Series
Mar 18, 2014 02:18 AM
Phanman43
Mar 4, 2014 07:08 PM
