tow/haul switch replacement
Old Jan 28, 2014 | 12:19 AM
jkey.bama's Avatar
jkey.bama
Question tow/haul switch replacement
Hi Guys,
I have a 2004 F350 dually 4x4 5spd/wod tranny. The day after I bought the truck (Nov 2013) the tow/haul switch quit working (light in instrument panel/not on end of shift lever). I need info/direction/instruction on replacing the lever switch from anyone who has accomplished this task.
I have not actually utilized the tow/haul function but will do so 80% of the time starting in the spring. I bought the truck exclusively to haul a 4 horse/living quarters gooseneck trailer (10,500 lb empty; 16,500 lb loaded).
I have no reason to believe the light is burnt out, so I will replace the shift lever switch (with someone's experienced direction) and see if the light will operate again.
Thanks for any help and direction!
Old Jan 28, 2014 | 07:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you just replace the switch come back here afterwards and I'll tell you why that didn't fix it. The switch hardly ever fails.
The problem is in the wiring to the switch. Where the wires enters the end of the shift handle in the steering column is where the problem is located. The wires rub and either wear through or the wire breaks inside the insulation.
Take the covers off of the steering column. Carefully inspect the wires and either repair the break or replace the entire shift handle. A new handle is about $65 at a Ford dealer.
Old Jan 28, 2014 | 05:17 PM
JWA's Avatar
JWA
Here's a link to replacing the part Mark references: Swapping auto collum shifter arm - PowerStrokeNation : Ford Powerstroke Diesel Forum
This ^^ same info is probably available here on FTE too however I've not yet seen it.
Norton72
Nov 27, 2015 03:41 PM
StanleyZ
6.4L Power Stroke Diesel
Oct 22, 2012 10:39 AM
J cam
Jun 15, 2009 09:29 PM
ol'yeller
Aug 10, 2006 09:58 PM
jesseh
Dec 4, 2003 12:20 PM
