Tow/Haul switch not working
Old Nov 27, 2015 | 10:30 AM
Norton72's Avatar
Norton72
My Tow/Haul switch does nothing. No light on the dash, does not shift out of OD. I've looked at the fuses and relays and can't see anything suspect. No codes. I have SCII and Torque Pro app with bluetooth adapter. Can I find out anything with these?
Old Nov 27, 2015 | 12:14 PM
Euroman's Avatar
Euroman
I spotted this problem before buying mine last year - it was a good spot because they had to replace the whole shift lever. Maybe you have the same problem
Old Nov 27, 2015 | 02:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When tow/haul is working it won't take it out of overdrive. That's not it's function. It changes the shift schedule.
The most common cause of this problem is the wires wear through where they enter the shift handle. You can take the cover off the cold and either fix the wires or replace the shift handle.
Old Nov 27, 2015 | 02:54 PM
Maxium4x4's Avatar
Maxium4x4
Replaced mine when I first bought my 03, the truck was possessed and would go into tow haul on its own. Wires were broke and I figured that is why the first owner dumped the truck. Only had 9k on the clock when I bought it.
Old Nov 27, 2015 | 03:41 PM
creator's Avatar
creator
The whole assembly comes apart and the wires can be soldered with some tiny heat shrink
Vettster
Aug 13, 2018 10:22 AM
jkey.bama
Jan 28, 2014 05:17 PM
letsroll93
Sep 7, 2006 01:20 PM
DUKFVR
Modular V10 (6.8l)
Aug 18, 2005 07:34 AM
Mike808
General Automotive Discussion
Aug 27, 2004 05:25 PM
