Sponsored by: Real Truck
'99 Overdriveoff Switch Failure
Old Aug 10, 2006 | 08:06 PM
ol'yeller's Avatar
ol'yeller
When pulling my travel trailer I usually switch off the overdrive when I find the transmission shifting up and down often. My truck is a '99 with the V10. On my last trip in Idaho and Montana, the switch sometimes didn't light up (or switch to OD off) when the switch is depressed. Being a guy, smacking the shift handle sometimes activates the OD off switch so obviously the switch is going bad. My questions are: how is the switch replaced, does the whole handle need to be replaced? Is there some contact made where the shift handle attaches to the column as moving the handle seems to make it work better? This is my first post here. My truck only has 70,0000 miles. Any help would be appreciated.
Old Aug 10, 2006 | 09:27 PM
sifon187's Avatar
sifon187
Ihave the same problem too. I was going to pull off the plastic covering the steering column to see if the wires for the switch are broken. You shouldnt have to replace the whole arm, but I would let someone else give you that answer.
Old Aug 10, 2006 | 09:58 PM
mullethead's Avatar
mullethead
In most cases the problem is the wire where it passes out of the shift handle. They usually break and the shaft has to be replaced. I have not seen many on-off buttons go bad but it is sometimes the case. You can get just the button.
civicmindeddogooder
Dec 23, 2019 08:56 AM
RunninD
43
Jul 23, 2012 09:22 PM
ol'yeller
All Things Towing
Oct 18, 2006 10:16 AM
TWolf
Montana Chapter
Jun 28, 2006 06:15 PM
Jimmie
Dec 5, 2003 11:16 AM
