6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tow/Haul switch intermittent
Old Dec 30, 2009 | 05:12 PM
StanleyZ's Avatar
StanleyZ
My Tow/Haul switch will not always turn the function on, and once on it will not always turn the function off. Sometimes I can get it on while still in park. sometimes not. Anyone have any ideas or experience with the same problem. Thanks.
Old Dec 30, 2009 | 06:18 PM
Tom's Avatar
Tom
Sounds like a frayed wire or a bad switch. If under warranty I'd take it to a dealer.
If not I'd pull the cover off the steering column and start testing wires to narrow down where the problem is.
Old Dec 30, 2009 | 06:22 PM
sdetweil's Avatar
sdetweil
not the same.. mine didn't work at all when I bought the truck.
broken wire in the shift lever..
take the upper and lower column covers off
unplug the cable on top of the column
test the switch action by using the wires at the connector..
I removed the shift arm retaining bolt, and took the arm to the shop..
the switch just rests in the column, I pulled a new wire thru and soldered it to the original (stub)..
same on the connector end..
Sam
Old Dec 31, 2009 | 06:29 PM
StanleyZ's Avatar
StanleyZ
Thanks, y'all. I'm still under warranty so i'll let Ford fix it, but I'm gonna save these directions just in case.
Old Dec 31, 2009 | 09:10 PM
2x6 bulldog's Avatar
2x6 bulldog
Mine T/H wire broke under warranty. Same thing happened to the O/D switch on my 99 SD.
Old Oct 22, 2012 | 10:39 AM
cdean45's Avatar
cdean45
SUCCESS!...Ive been having the same problem and took the covers off, Turned the Key on, Shifted to D, pushed the Tow haul Button while I wiggled the Tow Haul Wire that connects to the harness (on top of the column) and found when I bended it Right it worked.
I also found where the wire was not connecting was right where (towards the middle) all the stress is when you shift the lever
I will be reenforcing the wire heavily as I can see this is a flaw in design on a wire that moves. My truck started this around 125,000 miles
Thank you, now on to the same issue with Cruise, which I believe might be the PRessure Switch...
Big-Red-Lariat
2015 - 2020 F150
Mar 14, 2017 11:38 PM
DR Buck
Oct 16, 2016 10:12 AM
KW7DSP
Oct 10, 2015 01:58 PM
vastdavidson
6.7L Power Stroke Diesel
20
Jul 6, 2015 07:58 PM
superman724
May 18, 2008 02:46 PM
