In a junk yard off any F.I. truck and think van.
If you get them JY get the Y pipe also as some of the new ones the opening where the pipes join can be really small and need opening.
You can also get the manifolds new thru any parts store under Dorman replacement parts.
I did a little horse trading to get mine used and bought a new Y pipe think thru Rock Auto.
Dave ----
We considered a JY, but for about 70.00 each we just didn't think the time involved in pulling them was worth it. Non of JY's near us had any already pulled, but might be worth a call.
IIRC there is not a lot of room in the engine bay of the EFI's.
Thanks for the info. RockAuto has both efi manifolds for about $70 each, but out of stock on the Walker down-pipe. Will the Walker down-pipe bolt on to the exhaust pipe without welding?
Do they call it a down pipe or a head pipe or Y pipe?
Mine came with a cat and bolted right up to the manifolds.
I did have to come up with studs & brass nuts for the pipe hook up.
I also went with studs and nuts for the manifolds to head.
Dave ----
