Harmonic balancer bolt
Old Jan 20, 2014 | 06:53 PM
chefcharles's Avatar
chefcharles
I am having a heck of a time removing the harmonic balancer bolt on my 360fe. I can't get enough torque without turning the engine over.It's an automatic so I can't put it in gear.Any suggestions.
Thanks
Old Jan 20, 2014 | 07:00 PM
yetiman38237's Avatar
yetiman38237
I'm guessing you don't have impact wrench. I have wedged screw driver or pry bar on alternator or power steering pump.
Old Jan 20, 2014 | 07:12 PM
BobbyFord's Avatar
BobbyFord
Remove the coil wire. Put a breaker bar with a deep socket on the bolt and turn the motor clockwise until the handle of the breaker bar is on top of the left frame rail. Go inside and tap the motor over.
Old Jan 20, 2014 | 07:58 PM
orich's Avatar
orich
2X On the scary way if that's your only option.
We did my son 4wd toy that way. Best to use an impact socket tho..
orich
Old Jan 20, 2014 | 08:36 PM
yetiman38237
I like that idea.
Old Jan 20, 2014 | 11:09 PM
crazed87bronco's Avatar
crazed87bronco
That's a scary way but effective. That's one of the worst case scenario's. Might want to let the bolt and harmonic balancer soak awhile in some rust penetrant PB blaster. Mine have been very rusty before and took some work to break free.
Old Jan 20, 2014 | 11:48 PM
Aesop's Avatar
Aesop
If you don't care about the engine then drop a 3/8 extension down a spark plug hole on a upstroke, 1 inch from the top of the stroke. Or fill it with oil half way up the compression stroke and reinstall the plug. That is what works at a wrecking yard.
I am thinking you need an impact hammer. You might try renting an electric one if you don't have a compressor.
Old Jan 21, 2014 | 09:35 AM
Gembone's Avatar
Gembone
I have used this method on many vehicles and it has never failed or damaged anything.
chefcharles
Jan 29, 2014 11:19 PM
robjs111
Sep 22, 2012 08:49 PM
fordfan302
Apr 17, 2008 06:18 PM
ExcellentRed
Aug 1, 2004 04:52 AM
bigwhtbco
Jul 3, 2004 08:16 AM
