crankshaft bolt threading
Old Jul 29, 2004 | 07:22 PM
ExcellentRed's Avatar
ExcellentRed
Exclamation crankshaft bolt threading
Hey guys,
I'm in the process of taking off the timing chain cover and I need to remove the big 15/16 crankshaft bolt that holds the harmonic balancer on. Is that a lefty-loosey bolt or is it threaded backwards (due to the clockwise motion of the engine) ?
Old Jul 29, 2004 | 08:01 PM
ExcellentRed
Okay, I called a mechanic and determined that it is threaded normally, but I can't get it off! I have tried a breaker bar and a rubber mallet as well as an impact wrench. Any ideas?
Old Jul 30, 2004 | 01:31 PM
ExcellentRed
well guys, I answered my own question eventually. Here's the way to do it - keep the pulley on the harmonic balancer and wrap the pulley in a rag and a chain wrench. Then pull the chain wrench opposite of a breaker bar that is on the bolt.
And when you're taking off the harmonic balancer, do NOT use a wheel puller on the outside of the damper. It will mess it up!
Old Jul 30, 2004 | 08:54 PM
rainbowATF's Avatar
rainbowATF
Visegrips on flywheel blocked by bell housing and use impact wrench on balancer bolt; used this approach numerous vehicles. Just remember to remove those visegrips after the repair.
Old Aug 1, 2004 | 04:52 AM
rhodie's Avatar
rhodie
I used a breaker bar with a 5 foot section of pipe over that for leverage. Still was an effort, but got the thing off....
jrroth
2004 - 2008 F150
Apr 30, 2012 12:21 AM
hollygreenman
Oct 19, 2010 09:52 AM
earl82461
1997 - 2003 F150
Apr 4, 2008 09:56 PM
coplin
Mar 20, 2007 01:25 PM
1982fordf100
Aug 2, 2006 09:08 PM
