rotor question
Old Jan 20, 2014 | 10:05 PM
1999stroke's Avatar
1999stroke
rotor question
so I found a 80 f100 up for parts and I can get the rear end with 5x4.5 bolt pattern out of it my question is I also found a 76 f150 that I can get the spindles off of can I run the front rotors off of a 80 f100 with the 5x4.5 bolt pattern on the 76 spindles with 76 calipers if I put them on my 68 f100
Old Jan 21, 2014 | 10:05 AM
orich's Avatar
orich
I'd go to rockauto.com and look up the P/N's for each for a fast answer.
This is called doing your home work...
orich
Old Jan 21, 2014 | 11:10 AM
JEFFFAFA's Avatar
JEFFFAFA
I know bearing companies have books which lists bearings by size so figuring out which bearings and their races could be found. But I don't know if the rotors would line up with the calipers though.
Old Jan 21, 2014 | 11:24 AM
1999stroke's Avatar
1999stroke
jeff the bearings are the same for both and I know that they both take a floating caliper the only thing that I am seeing is that the rotor for the newer truck is about half an inch smaller in diameter this would all be a temporary thing as I want to do the cv swap eventually but the parts that I have found don't just pop up all the time so I guess my main question is will the smaller rotor be a bad idea or unsafe
Old Jan 21, 2014 | 11:59 AM
Aesop's Avatar
Aesop
If the brake shoe extends beyond the radius of the disc, then you will polish the disc edges, and step the pads in that area. If I had every intent to change the discs and pads in the very near future I would do it just to get on the road again. I certainly would not put thousands of miles on it.
Old Jan 21, 2014 | 02:38 PM
JEFFFAFA's Avatar
JEFFFAFA
2X Aesop. Brakes are your life. A good machine shop should be able to alter the correct rotors to the smaller bolt pattern. It is just the 9" rear axles can't be changed because of the 6th access hole in the axle flanges. With it there you can't add a 2nd (smaller) bolt pattern. The front rotors don't have that problem.
67fordok
Apr 2, 2013 10:21 AM
82f-100
Apr 16, 2009 10:30 AM
blown33
Jul 27, 2007 02:27 PM
droppedf100
Apr 22, 2007 10:49 PM
Shadow05
Aug 19, 2006 02:48 PM
