Flareside cargo/reverse light mounting ideas.
Old Jan 15, 2014 | 08:08 PM
broncoderek's Avatar
broncoderek
I got two rectangular driving lights for Christmas. My idea is to mount them to do triple duty: one is for aux reverse lights, two is for cargo/bed lighting and third to "tell" other drives to turn off thier high beams or quit riding my *** so close.
I'm trying to think of where and how to mount these to serve these purposes. All I can think of right now for location is about 8" higher than the front corners of the bed. This way I'll get aim-able light in the bed while also lighting the area behind the truck for backing up and the light can reach over the tailgate and into the car behind me (only if they deserve it).
So how do I get them up above like that? (I am going to wire them so I can manually switch them btw).
I don't have a welder or else I'd fab up 8" "stalks" to mount to the bed...
Old Jan 15, 2014 | 09:06 PM
Diesel_Brad's Avatar
Diesel_Brad
Bolt them to the roof of the truck
Old Jan 15, 2014 | 11:16 PM
UNTAMND's Avatar
UNTAMND
With your tailgate up, they will hurt you more than help for backup lights.
Backup lights need to illuminate from behind the body of the truck. I had lights on top of my roll bar for plowing, pointing forward and to the sides some, as well as pointing back, and they would be either aimed too far behind me to help a lot, or they would brighten the tailgate enough that it was still hard to see.
Best setup for reverse lights is bumper or side of the hitch mounted, with a 3 way switch, on, off, and auto(when you're in reverse they come on with your regular reverse lights). This setup is the best I've had.
I ended up mounting my lights on posts that fit into the stake pockets and pinned, then I had a plug for them. I could put them in any stake pocket pointing any direction. When I didn't want them looking goofy, they went in my truck box out of sight.
Old Jan 16, 2014 | 05:14 AM
broncoderek
That's the best location for me but I can't stand the idea of holes in my roof.
Old Jan 16, 2014 | 06:26 AM
dixie460's Avatar
dixie460
So mount them to steel plates, then epoxy some welding magnets to the bottom of the steel, and you got mag mount lights with no holes. Make a power cable to run out your window. Not really permanent, but that's about all you can do if you ain't willing to drill holes.
Or... just get a light bar. The only holes you need are to mount that. Then all the other holes go in the light bar itself.
Or... put a rollbar in the bed and mount the lights to that.
Just a few things to consider. I agree with the above posts where if you have your tailgate up and the lights are mounted low in relation to the bed, you won't be doing yourself much of a favor. Gotta be up high to work best.
I'd have done this a long time ago but my problem with cab top mounting is low hanging branches...
Old Jan 16, 2014 | 06:58 AM
broncoderek
Great ideas, thanks!
Top of tailgate would be cool I guess too (always compromises). I could turn them 180 degrees if I needed the light in the bed... It'd look goofy though.
Old Jan 16, 2014 | 08:43 AM
dixie460's Avatar
dixie460
Oh and I want to say that I saw a clamp-on light bar somewhere on the net... it clamped to the drip rails on the cab. Not sure how durable it is. I wouldn't buy one because I'd be afraid someone would steal it... not that I live in a bad place or anything, but it ain't a chance I'm willing to take.
Old Jan 16, 2014 | 11:05 AM
Fastback460's Avatar
Fastback460
You could get a headache rack if you want to mount them near the roof.
Or a light bar like this would work.
210341 CARR Light Bars - Deluxe (Black) for 93-96 Ford Bronco at Andy's Auto Sport
or
http://www.ebay.com/itm/ROOF-OFF-ROA...-/390722410592
Old Jan 16, 2014 | 04:44 PM
broncoderek
My biggest issue is the Flareside bed. I'd get the headache rack but never seen one for my truck...
Redrockerstl55
Jan 18, 2018 07:37 PM
bbwalker
Jul 11, 2017 03:46 PM
191124x7
Feb 2, 2017 03:30 PM
fordtruck661
18
Oct 20, 2012 06:24 PM
GrampsHandMeDown
2004 - 2008 F150
Dec 27, 2008 10:49 AM
