slow crank
Old Jan 15, 2014 | 07:35 PM
mknapik's Avatar
mknapik
slow crank
Slow crank with good batteries and charger hooked up . Does that mean starter is on its way out.
Old Jan 15, 2014 | 09:55 PM
tecgod13's Avatar
tecgod13
Check all the connections, both at the battery, the starter, and the grounds down to the block. If the cables are in good shape, and the connections clean and tight, then the starter is shot. But check the connections and battery cables first.
Old Jan 15, 2014 | 10:09 PM
mknapik's Avatar
mknapik
Connections are good above and on starter so starter it is . Next question j have a starter with no cone over gear that came off of another 7.3 that was a standard will it work it was a month old
Old Jan 15, 2014 | 11:22 PM
Macrobb's Avatar
Macrobb
Uh, pics?
all 7.3 starters should be the same, though apparently they come in straight and gear-reduction models.
Gear-reduction models are much better, BTW.
Old Jan 16, 2014 | 02:27 PM
Phy's Avatar
Phy
I believe that starters are different between auto & manual trans...
Old Jan 16, 2014 | 06:25 PM
tecgod13's Avatar
tecgod13
There are several different style starters for these trucks. I want to say the one with no nose cone is from a powerstroke, but it might work, I am not 100% on that though.
Old Jan 17, 2014 | 01:21 PM
mknapik's Avatar
mknapik
Better safe than sorry I'm getting a new one from advance with the gear reduction . Hopefully this will be the end to my problems
man-o-war
Mar 27, 2016 07:20 PM
hotrod351
Mar 31, 2015 02:29 PM
02TB250
Dec 4, 2014 06:27 PM
nickj11
Aug 8, 2010 09:11 PM
jle70
Jan 22, 2008 09:49 AM
