maybe starter
Old Mar 30, 2015 | 06:45 PM
hotrod351's Avatar
hotrod351
maybe starter
my starter has started to give e problems the last couple months, or longer, been getting worse. its in the 90.s here and when i go some where and then get back into my truck within a couple minutes it will hardly crank. i got home and load tested it, seemed great. how do i find out if its my starter for sure, the starter is many years old and the battery is only a year old.
Old Mar 30, 2015 | 07:04 PM
'89F2urd's Avatar
'89F2urd
its probably your starter. that's a tell-tale sign (no start when hot) that its failing.
it could be, however, your cables. ohm your old and crusty battery cables, disconnected from starter/solenoid/battery, and check for high resistance.
it could be a combination of both, but its likely just a failing starter.
Old Mar 30, 2015 | 07:57 PM
hotrod351's Avatar
hotrod351
cables are clean but can do a resistance test.
Old Mar 30, 2015 | 08:48 PM
krooser's Avatar
krooser
Make sure there isn't any corrosion between the steel block plate and the aluminum bellhousing that would cause an intermittent 'no start'… chased that deal for too long on my old '89 F150. Three starters, new cables, new solenoid… cleaned the corrosion on the bellhousing and all was fine.
Old Mar 31, 2015 | 02:29 PM
hotrod351's Avatar
hotrod351
well the rebuilt starter did it. had to leave my truck running while i went inside to get it. they did find when i bought it, 2005, and it only had a 1 year guarantee. nit bad for a rebuilt.
TritonF150
2004 - 2008 F150
Oct 26, 2014 08:43 PM
StrongRepublican
22
Feb 19, 2007 02:20 PM
Dett
Feb 15, 2005 06:40 PM
gordo350
Nov 19, 2004 06:22 PM
Motorcraftsman
Jul 28, 2001 11:19 AM
