Coolant Level Questions
Old Jan 15, 2014 | 05:12 PM
joejackF250's Avatar
joejackF250
I just recently posted on another thread about how I thought my truck was loosing coolant. I filled it with distilled water (about a quart maybe a little more) to the fill line and I took it on a test drive last night to get it up to temperature and once I got back I saw the lever dropped a little which I know is normal. Well just now I went to see if it went back to max fill line and it hasn't, it was the same as last night. Is this normal or did I lose the coolant? Everything is operating normal like the ECT/EOT temps were 5 degrees apart at max (182/187), no white smoke, no coolant smell, and no oil/coolant mixture.
That being said, what is normal coolant level "activity" in the degas bottle on a normal operating truck with no load and no problems? And after it sits overnight should the coolant rise back up or stay at a lower level?
Old Jan 15, 2014 | 05:18 PM
Magnus E's Avatar
Magnus E
I had a similar issue a while back. Got me real concerned so I took it to the dealer. Turned out to be a leaking radiator hose and the fix was a $3 dollar clamp. Might be worth it to look around all the hoses for any signs of leakage.
Old Jan 15, 2014 | 05:19 PM
jswartz84's Avatar
jswartz84
When the engine is cold, the fluid shoud be no higher then the MIN line on the degas bottle.
Old Jan 15, 2014 | 05:22 PM
joejackF250
Where exactly are the hoses, and how many?
Old Jan 15, 2014 | 05:28 PM
Magnus E's Avatar
Magnus E
There is one that runs from the bottom of the radiator to the driver side lower part of engine block. You have another one on the top of the radiator driver side. Then there are the two thinner hoses running to the expansion tank. A tricky one to check is the short little red one (or blue for some) at the EGR cooler. You'll find it under the intake manifold on the passenger side (sort of midway between the turbo and oil cooler housing). Finally, you have the hoses running to the heater core right on top of the passenger valve cover.
Old Jan 15, 2014 | 07:57 PM
69cj's Avatar
69cj
You also need to check the heater hoses and heater control valve.
Old Jan 15, 2014 | 08:44 PM
Fal-308-Win's Avatar
Fal-308-Win
If hoses are leaking you'll see white crusty spots at the leak point or below, or. wet spots on the driveway. Look under the Degas Bottle they crack after a while. Put a 0-30 psi Gauge on a coolant line to see if the system holds pressure. Mine holds steady at 8 PSI.
Old Jan 15, 2014 | 09:51 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The coolant level can vary quite a bit, almost like it has ADHD.
It's normal. Just stone cold make sure the level is no higher than the MIN line on the bottle.
Josh
spunout
6.4L Power Stroke Diesel
66
May 11, 2012 09:10 PM
Strokin-8
Oct 25, 2010 08:52 AM
mechelement
Feb 15, 2009 08:30 PM
w_huisman
Mar 1, 2008 07:31 AM
frenchf250
1997 - 2003 F150
Feb 27, 2004 11:43 AM
