6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Coolant level
Old Mar 12, 2011 | 11:10 AM
spunout's Avatar
spunout
Coolant level
I'm on a road trip from tx to Colorado. Filled up with coolant before we left. Stopped in raton NM over night and checked levels it's now sitting just below cold fill. Would temp, altitude, unlevel ground cause the reading to be off or lower coolant level?
Old Mar 12, 2011 | 01:03 PM
senix's Avatar
senix
By below cold fill...you mean the lower line? Sometimes ambient temps would do that.
Only you can judge whether you are stilling on level ground to take the reading.
If you have some coolant there is no harm in adding some so that you are at least in the middle between min and max line.
Ensure you are using the ford gold coolant or napa one that has the ford specs on the front of the bottle.
Old Mar 13, 2011 | 10:36 AM
StanleyZ's Avatar
StanleyZ
It seems the important thing is to never never ever let the coolant get below the little inlet hose just below the bottom "cold fill line". That lets air in and screws up the coolant system. Mine uses some on hard pull trips. It's not in the oil and it's not on the ground and it's not coming out the fill cap. So, about once a year I add a quart or so of 50/50 mix (ford coolant and distilled water) and write it off as one of the many things that puzzle me about this truck.
Old Mar 13, 2011 | 05:30 PM
marspec's Avatar
marspec
Did you check the level soon after driving for awhile? I had mine in Saturday so Son could instal new computer update and air filter. While hood was up I noticed coolant level even with lower level line and commented that it wasn't that low last time I checked. He opened the tank which relieved some pressure and the level came up to halfway between lower and top line where it was last time I checked. He said that happens frequently and not to worry if there's no indication of a leak or level doesn't change when checked under the same conditions. (It's nice to have your own personal diesel tech.)
Old Mar 13, 2011 | 05:40 PM
StanleyZ's Avatar
StanleyZ
when hot mine is well above the fill cold line. I am 4000 miles since last "adjustment" and level is down maybe 1/4 inch. All checks I stated now and before are in dead cold conditions.
Old Mar 14, 2011 | 06:33 PM
spunout's Avatar
spunout
Just check it once the engine got to normal temp and level is back up to to where I filled it up. I guess when the engine gets cold the level drops a little?
Old Mar 14, 2011 | 10:22 PM
spunout's Avatar
spunout
If I have to use napa coolant any chance this would void the warranty if I have egr problems
Old Mar 15, 2011 | 03:27 AM
R-T0r21on's Avatar
R-T0r21on
No. The NAPA gold coolant has the Ford spec #. Exact same stuff as the Ford, in a different jug.
Old Mar 15, 2011 | 04:57 AM
senix's Avatar
senix
look at the front of container from NAPA. It will have the ford spec on it....or don't buy it.
Old Mar 30, 2011 | 09:39 AM
spunout's Avatar
spunout
Well she is definitely using coolant. Had to add coolant the next week after getting back from Colorado. Its not on the ground and I cant find any signs of leak. I guess now is a good time to take to dealership and get the PCM recall as well. I have a list of symptoms that is for sure....white smoke when engine get to normal operating temp, exhaust smell in the cab, using coolant....This sounds like EGR cooler. Does anyone know if egr system is covered under 5yr/100,000?
Old Mar 30, 2011 | 10:02 AM
StanleyZ's Avatar
StanleyZ
I think they would have a hard time saying EGR wasn't part of both drive train and emmissions so it should be covered 5/50.
Old Mar 30, 2011 | 10:09 AM
spunout's Avatar
spunout
I hope so if in fact thats what it is.
Old Mar 30, 2011 | 12:03 PM
senix's Avatar
senix
It should be covered...they need to pressure test it to tell for sure. Maybe it is just the valve.
Old Mar 31, 2011 | 08:26 AM
Gwilkrrs's Avatar
Gwilkrrs
this weekend i noticed my coolant level drop as well. after a day of pulling heavy trailers i was checking fluids, i noticed the coolant level (with motor warm) was below the rubber hose on the bottle. the next am i noticed (motor cold) the level was back up to even with the hose...... i worry that the level fluctuates and allows air in........
Old Mar 31, 2011 | 08:32 AM
senix's Avatar
senix
Never let it below that lower line, expecially the hose as it will suck air, causing caviatation possiblites.
