Low on Coolant
Old Feb 27, 2008 | 05:07 PM
w_huisman's Avatar
w_huisman
Low on Coolant
First nice day outside and decided to poke around my new (to me) truck a little. Found something a bit disheartening.
The truck hasn't been started since Sunday, and the coolant level in the degas bottle was well below the minimum line, which I'm aware is the full line with the new sticker that's supposed to go on there. You can see the level in this pic:
I'm pretty sure I looked at the level not more than 2000 miles ago and it was right at the bottom of the min line, although I don't recall how cold the engine was. There's no evidence of puking.
I pulled some coolant out of the bottle into a clear coolant tester, and it looked like the usual green stuff (forgive me, I'm a Ford newbie and a bit color blind) except maybe a little more clear. It tested very high indicating that there was plenty of pure coolant in the mix.
I figure that I'll top it off (up to the min line) and pay a little closer attention to the level for a while. However, I don't know if the system takes regular green coolant or if its something special like the pink GM goo. So if someone could let me know about the coolant type, I'd appreciate it. I'd also appreciate any other constructive comments anyone has.
TIA!
Old Feb 27, 2008 | 05:15 PM
slowmans's Avatar
slowmans
you need the new ford gold!
Old Feb 27, 2008 | 05:32 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I believe you can also use Zerex GO5 coolant, don't think its a problem if you mix it. Green is NOT the right coolant, something with the silica and cavitation IIRC. If thats not right someone will correct me Thats about where my coolant is and stays at that level, and it doesn't seem to run hot.
Old Feb 27, 2008 | 05:50 PM
w_huisman's Avatar
w_huisman
Thank you both for your response. I just had my boy take a look at the coolant, and he tells me its pretty clear with a tint of yellow. Does that sound like the right stuff?
I'm also glad to hear what you say about the level, D8. I think I won't add any coolant and see if the level changes sometime in the next few hundred miles.
Old Feb 27, 2008 | 08:26 PM
paddler65's Avatar
paddler65
w_huisman
i own an 05 f-350 psd 4x4 cc auto. i have a plastic sticker on the degas bottle with max and min at a lower level. my bottle is the same as yours except for the sticker.
the ford parts man said they used green and gold in the 05 and maybe other models. he ask the mech. tech. before he sold me gold for my truck.
in va. in cold weather the level was correct and now in Fl. the level is high.
Old Feb 27, 2008 | 08:37 PM
w_huisman's Avatar
w_huisman
I still don't understand why this forum won't let me create a signature.
My truck is an 03 cc sb 4x5 srw auto with 62k on the ticker. Mostly clean oasis, aside from the flashes and a rear main oil leak.
I suppose yellow and gold would be the same?
Old Feb 27, 2008 | 10:19 PM
mhoefer's Avatar
mhoefer
No Gold is what you want in an 05. The min level is max and the bottom is min in an 05 with the sticker. It will go up when hot but cooled right down this is where it will sit. This is a TSB that goes wiht the re flash of the engines PCM to empty injectors on shut down and startup. You should be able to get the sticker and the re flash on 60k mile engine warrenty? f you still got some.
Old Feb 27, 2008 | 11:10 PM
brickie's Avatar
brickie
Thats very close to where my truck runs. Mine is an 03 build also.
Old Feb 28, 2008 | 12:55 AM
bismic's Avatar
bismic
I believe you need 20 posts - then can get a signature??
Our engines specify only the "Motorcraft Premium Gold" coolant - you can get into corrosion or wear problems down the road if you use (or mix) the wrong kinds. Several threads on acceptable substitutes. The Motocraft coolant is expensive, so if you are completely replacing the coolant, you may very well save $$'s with another brand - just do a little research first. I have seen several people recommend what D8chumley recommended so it is probably OK. If you are adding just a little bit, I would just go get a gallon of the Ford coolant. You can get it with or without the bittering agent - doesn't matter.
Old Feb 28, 2008 | 08:16 AM
w_huisman's Avatar
w_huisman
Thanks Mark.
Since I've never heard the term before, I'll do a search to find out about the bittering agent.
Can you buy the Motorcraft Premium Gold at Walmart? Napa? Or is it a dealer only item?
Old Feb 28, 2008 | 08:27 AM
69cj's Avatar
69cj
The cold level on my truck will vary by anout a 1/4 to 3/8 inch. Don't know why but it has done that since new and appears to be normal. I wouldn't worry about it unless you see evidence of puking or water in oil or exhaust.
Old Feb 28, 2008 | 09:06 AM
w_huisman's Avatar
w_huisman
I forgot to also mention my truck is a rebuilder, so no warranty. I can add/delete/modify as I see fit.
The truck as it sits has as much power as I'll ever need, so I'll mainly be working to improve reliability and mileage.
Cat will be coming off in short order (delete pipe arriving today). Maybe muffler too. Harpoon and coolant filter will be close behind that (I absolutely HATE how long it takes to fill this truck up). Followed by eliminating exhaust flow through the EGR one way or another.
And I'll repeat my last question so it doesn't get lost in the thread:
Old Feb 28, 2008 | 09:12 AM
paddler65's Avatar
paddler65
05 f-350 4x4 psd cc auto
what would you do if you had added a gal. of green coolant to the truck???
would you drain and replace anti freeze??
Old Feb 29, 2008 | 08:30 PM
sbrou14's Avatar
sbrou14
HAHA, I am in the same boat. I added 1.5 gallons of Prestone prediluted and was wondering the samething. Anyone?
Old Feb 29, 2008 | 08:41 PM
Kusto's Avatar
Kusto
When I had coolant loss my dealer said you could use any coolant suitable for diesel engines and it would be OK. Just what I was told but not sure.....
