torque wrench Necessary?
Old Jan 15, 2014 | 02:25 PM
Jerry Chaney's Avatar
Jerry Chaney
just put in my hpop, I don't have torque wrench, can I just tighten the **** out of it? and do I need gasket or oring on front cover plate?
Old Jan 15, 2014 | 02:50 PM
snakedoc's Avatar
snakedoc
if it is the cover over the gear bolt it is the ford gray glue.
Old Jan 15, 2014 | 03:32 PM
Tugly's Avatar
Tugly
The HPOP drive gear doesn't have a positive grip on the shaft - torque is critical, and the engine will spin before you get it torqued to spec.
Old Jan 15, 2014 | 03:38 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Get a torque wrench. You will need it for lots of things. Its one of the most essential tools you can own.
Old Jan 15, 2014 | 03:47 PM
acf6's Avatar
acf6
A good torque wrench at that, not some $10 harbor freight thing
Old Jan 15, 2014 | 03:52 PM
Jerry Chaney
nice truck man..
Old Jan 15, 2014 | 04:05 PM
HKusp's Avatar
HKusp
Yes, what they said. 96 ft/lbs and the engine turns over at about 85 ft/lbs so you will need someone with a good sized wrench on the crank pulley to keep it from turning the engine over. On the front cover, I used Permatex, black. It is rated to 550 degrees which should be adequate for the that location.
Old Jan 15, 2014 | 06:33 PM
Jerry Chaney
great, thanks man..
urbex
Large Truck
Oct 10, 2017 01:36 PM
tonefordays
Jan 7, 2012 04:04 PM
TransplantX
Apr 25, 2009 05:41 PM
cdiddy
Garage & Workshop
Feb 28, 2007 11:15 PM
old hippy
Garage & Workshop
Jan 28, 2003 08:44 PM
