Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
bolt torque
Old Jan 24, 2003 | 08:04 PM
old hippy's Avatar
old hippy
bolt torque
does anybody remember the formula for ft lbs of torque lost for every inch of extension added.
thanks
Old Jan 25, 2003 | 11:07 PM
Torque1st's Avatar
Torque1st
Posting Legend
bolt torque
I have never heard of it. Are you talking about the torque produced by an impact wrench? A torque wrench should not matter.
Old Jan 26, 2003 | 01:42 AM
Stab's Avatar
Stab
bolt torque
I think as long as you are using a straight extension there is no difference. I think the torque equation only comes in to play when using a wobbler, u-joint socket, crowfoot......etc.
Old Jan 26, 2003 | 09:54 AM
wabiker's Avatar
wabiker
bolt torque
yes there is a formula for extensions both for handle and depth...no I cant remember what they are though...sorry
Old Jan 26, 2003 | 06:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
bolt torque
I wouldn't think they would be very accurate since the torque loss using an extension with an air impact would depend heavily on the physical properties of the extension material. There are calibrated torque limiting "extensions" used with air impacts used in tire service shops.
There would be no torque "loss" using an extension with a torque wrench unless the wrench is not "straight on" with the bolt or nut.
There are formulas for use with a crows foot type wrench.
Old Jan 27, 2003 | 08:19 AM
AOGDEN's Avatar
AOGDEN
bolt torque
PM me with a fax number, if possible. I have a manual from a torque wrench mfg. that shows all of the different ways to calculate the torque. A lot more than I can type here. The basic equation is as follows:
Ta = Torque exerted at the end of the adapter
Tw= Torque wrench scale reading
L = Lever length of torque wrench
A = Length of adapter
Ta = Tw x ( L + A )
L
I don't know if this is what you wanted but I hope it helps.
Old Jan 28, 2003 | 08:44 PM
old hippy's Avatar
old hippy
bolt torque
thanks for the help, greatly appreciated!!!
dieselbronc
Mar 4, 2021 10:10 PM
FortyFords
Sep 17, 2002 09:05 PM
nevernuf
Aug 19, 2002 11:18 AM
Earl
Feb 26, 2002 09:21 PM
beisel
Dec 6, 2000 04:55 PM
