Sponsored by: Real Truck
Battery Parasitic Draw Testing
Old Jan 8, 2014 | 10:20 PM
makuloco2000's Avatar
makuloco2000
I didn't want to leave you diesel guys out in the cold just because you guys have 2 batteries and this is less common of a concern. It still can be of concern with all the glow plugs and starter amperage required upon cold starts not to mention most leave their autolamps to on so they come on and draw for the cold start too. So a draw still can be a problem and what a pain it can be. If you have this problem follow my video on how to track down that draw and see where its coming from and eliminate it. These winter temps this year are nothing to mess with. I sure hope this helps it is as simple as it get and is ford specific. Only one change for you diesel guys is take the neg terminal off the other battery so all the draw flow through your multimeter over at the other battery you are jumpered inline to as shown in the video.
Old Jan 8, 2014 | 11:14 PM
99f350sd's Avatar
99f350sd
Good post Thanks...Not many people know how to do this...I have a clamp on meter its just easier..so you don't have to disconnect anything..
Dick
Old Jan 9, 2014 | 08:08 AM
DavidB's Avatar
DavidB
Doing voltage drop testing across the fuses is generally an easier, faster, and better way of looking for the current draw, rather than pulling fuses. I don't have a video prepared to show this, but here is a pretty good one from youtube:
Old Jan 9, 2014 | 08:30 AM
Bobbykjl's Avatar
Bobbykjl
Great information - Thanks for sharing!
Old Apr 27, 2014 | 08:52 AM
Mikec35's Avatar
Mikec35
How To Perform a Battery Draw Test - YouTube
Good video! What's the reason for 2 jumpers instead of one?
Old Apr 27, 2014 | 09:44 AM
Tedster9's Avatar
Tedster9
How does two batteries lessen the concern for parasitic draw? The potential for problems is probably doubled, too.
Sent from my iPhone using IB AutoGroup
Old Apr 28, 2014 | 10:17 AM
speakerfritz's Avatar
speakerfritz
in the second video the testor is testing one lead on a fuse pin while having the other lead on the chasis ground. thats not a voltage drop test...thats a voltage test.
a voltage drop test would have a test lead on each pin of the fuse....which of course makes no sense since the resistance of the fuse is so low that you would never get a voltage drop.
Old Apr 28, 2014 | 08:29 PM
makuloco2000
Just to handle more amperage and therefore there wont be no new module malfunctions causing them to not go to sleep or other weird electrical issues caused by low voltage.
I am saying if you have a combined 1500 CCA on a diesel a little draw may not even be noticeable, but on a car that was designed with a battery that was just enough or as in the case of the Ford Edge a battery that was specd too small in the first place it will show almost every time.
Yes he is testing the voltage drop of each fuse as I see it which is null in this case.
Old Apr 29, 2014 | 07:12 AM
DavidB's Avatar
DavidB
You need to look at the video again (and listen to the audio). The test IS across the fuses, not to ground. It IS voltage drop testing. You DO get a voltage reading if there is a current draw. Either method will work, but the voltage drop testing is faster, safer, easier and 100 per cent reliable WITHOUT the problem of "waking up" modules and having to wait for them to go back off. "Try it, you will like it."
Dave
Retired Electronics Instructor
It is only "null" if there is no current draw.
Old Apr 29, 2014 | 10:55 AM
donovan's Avatar
donovan
Thank you.
That will help.
danw64
Electrical Systems/Wiring
Nov 8, 2014 08:18 PM
fcgllc
Nov 10, 2010 02:48 PM
flatbedjeff
Mar 22, 2006 07:22 PM
Hello
43
Sep 15, 2005 01:56 AM
Chipster
1997 - 2003 F150
Feb 4, 2004 05:10 PM
