Parking sensor always OFF
Old Jan 7, 2014 | 07:03 PM
nikiter's Avatar
nikiter
My truck just came out of the shop. Was in for spark plug change.
My parking sensor button is lighted up with OFF. I tried pressing it but it stays in OFF and no beeping occurring when in reverse and there are objects behind me.
What could it be? Fuse?
Thanks
Old Jan 7, 2014 | 09:47 PM
FireMe's Avatar
FireMe
This is due to an error in the park aid system. Could be bad sensor, failed module, or anything in between. You will need to have diagnostic equipment to run a self test on the system and see what codes are present, then follow the service manual from there.
But yes, it could be a blown fuse. Then the question becomes what part is bad that caused the fuse to blow?
Old Jan 8, 2014 | 01:54 AM
ojai150's Avatar
ojai150
You might start with calling the shop that changed the plugs, it might be a simple fix they know about.
Old Jan 8, 2014 | 07:20 AM
nikiter's Avatar
nikiter
I did right away. They don't know, and its a buddy's shop too.
Old Jan 8, 2014 | 11:38 AM
fordgirl5149's Avatar
fordgirl5149
A trained Ford tech would be the way to go on this one.
Old Jan 9, 2014 | 07:08 AM
nikiter's Avatar
nikiter
So it worked a couple of times. I swear it's almost temperature sensetive. Annoying.
Old Jan 10, 2014 | 09:45 AM
DavidB's Avatar
DavidB
Check to be sure that the sensors are clean and that connections are tight. Check for loose or chafed wires.
nikiter
Electrical Systems/Wiring
Jan 15, 2014 05:55 PM
740steve
Aug 22, 2013 03:24 PM
kdtupper
Oct 10, 2008 10:31 AM
ErnieX
May 9, 2008 07:43 AM
KNJC0205
Feb 1, 2007 07:56 PM
