Didn't realize my CEL was on until I worked on the cluster an replaced some bulbs - CEL was burnt out! Anyway, 96EXP has rough idle at start up and a little smoother but still rough after warm up. Took it to AZ to have the codes read and got the following:
P0141 - I believe this is for HO2S Bank 1 Sensor 1 - circuit malfunction
P0153, P1151, P1152 - These are all HO2S Bank 2 Sensor 1 - with all these bank 2 codes would it be reasonable to assume the B2S1 HO2S is shot and should be replaced?
Not sure about the P0141 - is this telling me I have a bad wire, connection, etc. or should I just replace both sensors and see if it corrects?
Yeh, the sensors are original - so guess I'll replace them both while I'm at it. I checked the fuse and it was okay. I believe there are only two o2 sensors on this model so it shouldn't be too bad.
Thanks for the input guys. I'll post with the results after I work on it this weekend.
