Back Up Sensors
Old Jan 31, 2007 | 01:56 PM
KNJC0205's Avatar
KNJC0205
Back Up Sensors
The back up sensors on my '03 EB quit working. I can set the switch to on, but when I put it in reverse it automatically goes to off. I was going to check the fuse, but looking in the owners manual I don't even see the back up sensors listed in the fuse panel. I also heard that if one sensor goes bad the system won't work. Any of you guys had a similar problem?
Old Feb 1, 2007 | 08:14 AM
EpicCowlick's Avatar
EpicCowlick
Perform a search on this forum. You'll find plenty of information about failed backup sensors. Bottom line is if one of the sensor goes bad, the whole system fails. You'll probably need to buy a single new sensor and replace one at a time until the system works. Then you know which sensor was bad.
Old Feb 1, 2007 | 07:56 PM
jdadamsjr's Avatar
jdadamsjr
also try cleaning all sensors, then looking behind your bumper for loose/corroded wires connections...
Wesley Redondo
Modular V8 (4.6L, 5.4L)
Jan 26, 2017 01:38 PM
Danjo523
Jan 17, 2017 08:29 PM
Teamrope
Nov 25, 2015 07:14 AM
Jr Saint
1997 - 2003 F150
Jun 12, 2015 12:04 PM
nofortunateson
Dec 25, 2007 09:25 PM
