Transmission Range sensor 2001 E350
Old Oct 10, 2008 | 09:36 AM
kdtupper's Avatar
kdtupper
I hqve a 2001 E350 and the back up lights do not work. I discovered that fuse 12 (15A) was blown. This fuse also controls the Transmission Range Sensor. I relaced the fuse and the back up lights still do not work. Will a faulty transmission range sensor cause this problem and if so will there be any code that would confirm this?
The replacement fuse has not blown.
Old Oct 10, 2008 | 10:31 AM
projectSHO89's Avatar
projectSHO89
There will be no fault codes.
Most likely, you have (or had) a short circuit in the backup lamp circuit.
F12 feeds the TR sensor solely for the purpose of it switching the backup lamps on when the selector lever is placed in reverse.
Worst case, the TR sensor has also failed and now won't switch the lamps on.
Steve
Smokdivr28
1997 - 2003 F150
Aug 20, 2021 06:50 PM
porkchop0119
Jun 8, 2016 06:12 PM
AliceSML79
Feb 8, 2016 06:43 AM
wa03f250
Apr 19, 2011 10:13 AM
Troy494
1997 - 2003 F150
Jul 24, 2010 02:05 PM
