Below 0 Celsius
Old Dec 31, 2013 | 04:21 PM
7.3dieseldennis's Avatar
7.3dieseldennis
Question Below 0 Celsius
I have a 1990 F250 7.3 that will only run above 0 Celsius
I added deicer to both tanks and let it run up too temperature.
It starts on days that the temperature is above 0 with no problem
But as soon as the temperature drops into the minus it starts and runs for about 10 or 15 seconds and its like someone shut the fuel off.
Every time I have plugged it in for 30 mins or more so the engine is warm.
Would it be possible that the fuel filter has moisture in it and freezes when the temperature drops, today it was -10.
Old Dec 31, 2013 | 04:44 PM
wtroger's Avatar
wtroger
Gets some diesel fuel conditioner (I like Howells) you could have moisture or gelling issues. It will help
Old Jan 1, 2014 | 08:02 PM
speedwrench72's Avatar
speedwrench72
in that cold u must plug her in for 3 hrs or more, and u may have your fuel heater not working, and ice in your filter, plug it in and get it running, go to some place that sells winterized fuel, and buy some diesel 911 additive, then a new fuel filter, change the filter when engine is warm, helps on restart, fill new filter, with clean fuel, and restart, and let idle, and keep it plugged in. its cheaper than one might think.
Old Jan 1, 2014 | 08:45 PM
Macrobb's Avatar
Macrobb
If your GPs are working right, and your engine even /half/ works, you shouldn't need to plug it in -- I've never plugged mine in(or my dad's, for that matter) and ours start fairly easily, even in 10F temps(below 0C by far). My filter heater's completely disconnected, BTW -- But it's fairly dry here, so I don't have any water in my fuel.
I'd:
1. Check that all of your GPs work. A piece of wire between the + terminal on the battery and each GP should give you a small spark when you touch the GP terminal. If you get nothing, the GPs going to be bad.
2. ice. After running it for a while(to thaw things), see about draining the separator. Perhaps also use some Power Service Products is America's largest manufacturer of technologically advanced diesel fuel additives. PowerService additive(white bottle, not gray. Red may also be a good idea).
Old Jan 2, 2014 | 07:25 AM
MPoulson's Avatar
MPoulson
I would start with a new fuel filter.
Sounds a lot like ice.
Those diesel 911 and K100 products are good at absorbing water but they don't work if there is a half a gallon sloshing around in the bottom of the tanks.
Old Jan 5, 2014 | 11:49 AM
7.3dieseldennis
I think it might be a gelling issue.
I added some anti-gel to both tanks.
It's plus 1c today and the truck started and quit on the first try.
I waited about 1/2 hr and tried it again and it started and stayed running this time.
Old Jan 5, 2014 | 03:41 PM
bashby's Avatar
bashby
You may have an intermittent air intrusion issue and the temp could just be coincidence. Next time it does it unscrew the fuel filter and see it it is full to the top.
Old Jan 8, 2014 | 08:17 AM
MackGuy's Avatar
MackGuy
I have a similar issue in my truck, it seems like it has air intrusion only when it's cold out. If it's 50 (F) or above it can sit 2 weeks and start on the first crank. When it gets much below 30, it will start then die, then I crank for ever and it will eventually re-start after just 2-3 days of sitting. My theory is that when it gets really cold the various seals contract allowing air in, while these seals stay sealed when it's warmer. Maybe now that it's really cold out I should go tighten up the fuel filter, as that's where I found a leak before.
Old Jan 8, 2014 | 08:24 AM
Chevy_Eater's Avatar
Chevy_Eater
I don't start below 0 degrees either.
The truck probably would, but I sure don't.
Old Jan 8, 2014 | 09:06 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Our service truck does this... gets quite anoying. The good news however, easy access to wrenches and the lines are easy to get to
Old Jan 8, 2014 | 09:50 AM
Gettysburg150's Avatar
Gettysburg150
Mine starts below 0C, it just dont like to.
Ther other day was 12F and took about 3 seconds of cranking to fire. She started to run very rough and missed, I increaed idle a little bit and it picked back up. I kept the idle about 900-1000 til it warmed up. Next time I will park close enough to plug in the heater
Old Jan 8, 2014 | 06:40 PM
kla94's Avatar
kla94
I've got similar issues. This is the first time it's happened to my truck. Just replaced the filter and fixed the fuel heater leak about a month ago. Replaced the glow plugs just after that. I think mine is fuel related as if I try to start it, she turns over several times before even trying to hit.
Old Jan 8, 2014 | 08:35 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
If your glow plug system and injection system is in good shape you DO NOT need to plug the block heater in for the engine to start. The other day at work my truck sat outside for about 10 hours with a windchill down to roughly -35*F. no block heater, got in it and cycled the plugs, gave it full throttle and cranked it over. it turned over pretty good, coughed a little at first but i held the idle up a bit to help it clear up for a few seconds.
Old Jan 9, 2014 | 08:24 AM
wtroger's Avatar
wtroger
If the glow plug system is good, batteries and starter, block heater are good and it still won't start then it has to be fuel. Either the fuel is gelling or Orings when they get cold don't seal as well allowing air intrusion. Treat your fuel. And the best thing I ever did to get mine to start was add the facet / carrier fuel pump. $80.00 for the pump and 2 hours to install has been well worth it.
Old Jan 9, 2014 | 05:35 PM
kla94's Avatar
kla94
This is my next step with my truck.
cross27
48
Jan 4, 2013 08:44 AM
FordTruckNoob
42
Mar 2, 2008 08:08 PM
Jacksfirstdiesel
Feb 22, 2007 07:36 PM
71 Muddbugg
Nov 5, 2005 06:49 PM
tim brown
Jul 13, 2004 05:09 PM
