T444E waterpump
Old Dec 30, 2013 | 01:20 PM
timmyboy76's Avatar
timmyboy76
T444E waterpump
http://www.dieselsite.com/1996-2003f...terpump-1.aspx
Old Dec 30, 2013 | 03:08 PM
clux's Avatar
clux
$350 for a water pump?
Holy sheepdip...................
Old Dec 30, 2013 | 03:34 PM
h2guy's Avatar
h2guy
Theres more in the kit than just the pump
Old Dec 30, 2013 | 03:50 PM
clux's Avatar
clux
Yeah, $20 worth of filters, $20 worth of radiator hose, and $20 worth of other parts.
Old Dec 30, 2013 | 04:24 PM
Stewart_H's Avatar
Stewart_H
Especially when Clay carries OEM 7.3L PSD water pumps for $158 bucks.
OEM Powerstroke Water Pump - Riffraff Diesel Performance
Stewart
Old Dec 30, 2013 | 06:35 PM
diehardstroker's Avatar
diehardstroker
or get the other ford water pump from dieselsite with a lifetime warranty. since were on the subject do you use RTV when replacing a water pump? and where can you get new bolts?
Old Dec 30, 2013 | 07:18 PM
SpringerPop's Avatar
SpringerPop
I don't use RTV.
I use a very light film of Aviation Form-A-Gasket.
Works very well on the thermostat housing, and intake extension o-ring, too.
No leaks, no comebacks.
Pop
Old Dec 30, 2013 | 07:26 PM
firedewd's Avatar
firedewd
Just happened upon this one yesterday. Didn't look into it much though. $188 includes shipping.
http://www.ebay.com/itm/1823669C92-NAVISTAR-WATER-PUMP-444-T444E-7-3L-/291035488983?pt=Other_Vehicle_Parts&hash=item43c31122d7&vxp=mtr
Dale
Old Jan 18, 2014 | 10:48 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Got my pump from bus parts experts. About $130. I did that conversion and sourced my own parts for about $235.
Old Jan 19, 2014 | 12:02 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Nicmike
I did that conversion.
Why?
Other than the built in water filter on the bottom, was there any other physical or mechanical reason?
Old Jan 20, 2014 | 06:41 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
My stock pump was shot and needed to be replaced. I wanted coolant filtration. This accomplished both replacing the pump and getting the filtration. I did not want the clutter the aftermarket filters create near the driver's side battery and alternator.
Old Jan 28, 2014 | 12:18 AM
BadDogKuzz's Avatar
BadDogKuzz
I like this set up over the stock Ford pump not only because it has a built in filter base, shut off valve, no more heater hose coming over the fuel bowl bolts & HPOP front cover and by looking at the photo of Mike's/ Nicmike pump it has cleaner lines. It looks like it belongs there and looks heavy duty. I hope Mike will post a photo. Honestly I do not like the look of a coolant filter hanging out there up top side. It looks like an after thought and I have read about some bases leaking and if it doesn't, even if you have valves it's going to leak some when you change it and dripping down the side of the radiator. Where with the IH water pump the filter is where filters should go. That is at a low point to where when it drips, it will only hits the drain pan. To me that alone is worth the cost. I know to some that doesn't matter as far as what drips where.
I'm kinda funny about where things drip!
And after reading the ad it comes with everything you need including thermostat, billet housing a lower hose that is worth $75 compared to the flex hose that costs $50. And if it is an actual IH / Alliant pump you are looking at $380 in parts.
So $20 to put it together as a kit is worth it to me.
Not include shipping.
If I go with a new Ford pump I also need or want a billet thermostat housing, thermostat, lower hose pipe it would cost me $250 Now I still need a coolant filter set up $130. So I'm looking at $380
Now I have read others have pieced IH pump (not Alliant) together around $250. And to keep it fair add a billet housing cover $45 which would be $295
Not including their time, tax or fuel.
Choices................. Time and money will tell which way I go.
Awitte58
37
Jan 31, 2016 08:33 PM
Blue7.3
Australia Chapter
Nov 5, 2014 02:26 PM
nookiemonster55
Oct 26, 2013 09:02 PM
74X4DOOR!
Sep 6, 2013 02:10 PM
DPhillips
Jul 10, 2004 04:56 PM
