Water pump question
Old Sep 4, 2013 | 01:18 PM
74X4DOOR!'s Avatar
74X4DOOR!
Water pump question
Hey Guys!
I need your opinion on something. Yesterday I picked my '05 6.0 from the shop after have the head gasket/stud job. In the process of the repair I also replaced my radiator hoses and water pump. Not ten miles down the road the lower hose came off and emptied the contents of the radiator. They acknowledged that but say that the water pump I supplied was leaking and defective. Since I supplied the NEW not rebuilt pump the repair is on me. I spoke to someone at Gates, the mfg of the pump and he says that the pump running dry is the most likely cause of failure. Do you agree?
Old Sep 4, 2013 | 02:18 PM
r2millers's Avatar
r2millers
Not sure what the water pump has to do with the lower hose coming off. If the shop didn't put one on or at least tightened it, they have to be liable for this. The water pump shouldn't have anything to do with the hose coming off.
Am I missing something here?
Old Sep 4, 2013 | 02:54 PM
diesel_dan's Avatar
diesel_dan
^^^^^^^^^^ X2 -- the pump didn't cause the lower hose to come off but them not tightening down the hose sure could cause a pump issue. But I'm worried what else cooked with no coolant?
Your shop sounds shady -- they must know they messed up....
Old Sep 4, 2013 | 05:27 PM
69cj's Avatar
69cj
I don't care for lawyers but I think I'd at least be interested in a free consultation and go from there. A trashed water pump isn't going to pop a properly anchored water hose. The degas cap pops at 16 psi. Long before a hose clamp should let go.
Old Sep 4, 2013 | 05:40 PM
npccpartsman's Avatar
npccpartsman
And if they knew the pump was indeed defective and leaking and they didn't inform you of that fact then they are, IMHO, liable regardless. And NO, the pump could NOT have caused the hose to come off. Their argument would never stand up in court.
Old Sep 4, 2013 | 10:28 PM
74X4DOOR!'s Avatar
74X4DOOR!
Well, the owner of the shop is convinced that the water pump I supplied was defective. I also supplied new motorcraft hoses that had the spring clamp glued to the hose. He says that the pump was leaking and the coolant loss caused the temp to rise, which it did, gradually, until the pressure caused the hose to blow off. I didn't have a choice and had to pay the bill for the new pump. I am however filing a labor claim with gates. They will examine the pump and if defective will reimburse me for the labor and refund for the pump. If they say it was a failure due to running dry then I will have to go back to the shop. This guy has a great reputation and I want to trust him. I guess it's wait and see at this point. I just hope that with all the new stuff that I am done with repairs. The truck does run great with no issues, and with the tune is noticeably more powerful. I did head studs, egr delete, oil cooler, HPOP w/ new IPR, resurfaced heads, hoses, belt, SCT tuner, and yes....new water pump.
Thanks for the feedback!
Old Sep 5, 2013 | 04:34 AM
npccpartsman
No way did the pressure cause the hose to blow off. Did you have coolant all around your degas bottle cap? It blows off at 16 psi. I've had more than one truck sitting in my driveway flushing the cooling system at operating temperature with the bottom radiator clamp not even on the hose and NEVER had one even leak, much less blow off, and that's running the RPM's up to the 2500 plus range. This shop owner is just trying to get off the hook for fixing his screw up.
Old Sep 5, 2013 | 05:31 AM
mustang_309's Avatar
mustang_309
I would imagine a shop worth its salt would have test ran the truck up to full operating temp and then brought the truck back and checked for leaks on anything they had touched. Had the pump been leaking they would have known it then.
Old Sep 5, 2013 | 05:50 AM
npccpartsman
Do you care to name the shop where the truck was repaired?
Old Sep 6, 2013 | 01:48 PM
r2millers's Avatar
r2millers
You have taken this guys "trusted" advise and he has you... hook, line, and sinker.
His nickname buffalo bill be cause he's buffalo'd you big time.
You ask for advise here, you get an overwhelmingly one sided opinion, and you trust old buffalo bill anyways.
Just don't get it.
Old Sep 6, 2013 | 02:10 PM
Bonanza35's Avatar
Bonanza35
I agree with all above. You got taken. Hope you stopped driving it and didn't hurt anything else. That's what the shop is worried about. Not the pump and coolant. If its not on your reseat, the pump wasn't leaking. They left the hose loose and didn't test the vehicle.
arsleuthster
Oct 28, 2025 12:54 PM
timemachine455
May 29, 2019 02:14 PM
77 Stepside
Dec 29, 2016 01:16 PM
pkon
1997 - 2003 F150
Oct 2, 2007 09:24 PM
DPhillips
Jul 10, 2004 04:56 PM
