glow plugs
Old Dec 30, 2013 | 11:36 AM
farmer ford's Avatar
farmer ford
glow plugs
where is the glow plug controller/relay? this truck used to start fine at 20 deg now it has to be plugged in all night. any help would be great thanks all
Old Dec 30, 2013 | 11:58 AM
dc2842002's Avatar
dc2842002
Glow plug control module is on the passenger side valve cover. Also check FICM output
Old Dec 30, 2013 | 01:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Likely FICM voltage. The glow plug circuit is pretty good at throwing codes if there is an issue.
Josh
Old Dec 31, 2013 | 11:18 AM
farmer ford
ficm has 47.5V there are no GP codes thrown. maybe its just to cold but something doesn't seem right about that
Old Dec 31, 2013 | 12:05 PM
npccpartsman's Avatar
npccpartsman
You can have the correct FICM voltage and still have a failing FICM. If you have GP issues the truck will throw a code but not necessarily a CEL
Old Dec 31, 2013 | 03:37 PM
Dyllan78's Avatar
Dyllan78
I'm having the exact same issues, no gp codes. FICm showes 48v. Truck won't start if I don't plug in, and when it does it barely goes until fully warmed up.
Old Dec 31, 2013 | 06:54 PM
m-chan68's Avatar
m-chan68
***INJECTOR(S)***.
robertc1980cj7
May 11, 2018 05:16 PM
renoduckman
Jan 5, 2016 05:47 AM
lukeg
Apr 9, 2012 07:48 PM
MustangMatt96GT
37
Feb 9, 2009 11:57 AM
sippie
Jan 9, 2008 10:52 AM
