Possible Starter problem????
Old Dec 29, 2013 | 11:11 AM
Bobbys Big Red Rig's Avatar
Bobbys Big Red Rig
Working on my daughter's 6.0
Would not turn over, dragging like a bad battery. Found that positive cable was bad and replaced. Did a little better. Had batteries tested an one tested bad, replaced both. Much better but still dragging. Have checked grounds and one will snug to frame but will not lock down tight, gets very snug so not sure if that is an issue, found stripped threads from hole.
Was leaning towards the starter dragging. What is best was to test. Will turn over but very slow. FYI, I have had truck plugged up and temps have not gotten lower than 30*
Old Dec 29, 2013 | 11:35 AM
npccpartsman's Avatar
npccpartsman
You can take the belt off and see if it turns over better. Possible that something (usually compressor) is dragging it down. Grounds are very important. You can move a "stripped" ground to anywhere else that a bolt will thread in to. How many miles on this starter, not that it matters. NAPA makes a GREAT replacement starter for the 6.0.
Old Dec 29, 2013 | 01:44 PM
Bobbys Big Red Rig
Assuming it's the original, 160k
Try to find a new grounding place that cable will reach. If that doesn't fix it then guess I will take starter to be checked out.
Old Dec 29, 2013 | 02:35 PM
npccpartsman
Yeah......bean counters make things like that a challenge sometimes. Everything is so position specific it's hard to "shade tree" anymore. It may be quicker for you to pull the starter and have it checked than repair the ground cable....
Old Dec 29, 2013 | 02:45 PM
Maxium4x4's Avatar
Maxium4x4
I would pull the belt and make sure before you go get another starter.
Old Dec 29, 2013 | 03:29 PM
Bobbys Big Red Rig
Well got it grounded good and still the same. Had starter pulled before I saw last post. Taking it to a local Starter and Alternator shop tomorrow to be checked out.
Educate me on what I would have been looking for if I pulled belt and tried cranking? I take it that if it turns over good, starter is good. But what would have been next??
Old Dec 29, 2013 | 04:48 PM
npccpartsman
You start checking to see what accessory is frozen/difficult to turn. AC compressor, water pump, power steering, etc.
If it was me I wouldn't spend too much on getting the starter fixed. IIRC you can get a reman from NAPA for about $160 that cranks quite a bit faster than stock. I've had excellent service with mine.
Old Dec 29, 2013 | 05:27 PM
Yahiko's Avatar
Yahiko
Just in case it is a bad cable here is how to test.
Looking at the insulation jacket is not a good indicator.
Sean
Tennesseepowerstroke
1983 - 2012 Ranger & B-Series
Apr 29, 2014 11:20 PM
JoeHarbourJets
Nov 7, 2011 09:12 PM
awils961
Virginia Chapter
Feb 11, 2011 05:15 AM
460/5
Jun 30, 2010 10:07 PM
gordo350
Nov 19, 2004 06:22 PM
