WTB Scangauge
Old Jan 6, 2014 | 09:28 PM
  #61
Fal-308-Win's Avatar
Fal-308-Win
Your correct about +&-. You had to enter 2 zeros first? So you have 10 digit codes? Where did you get them?
Old Jan 6, 2014 | 09:33 PM
  #62
Fal-308-Win
For fmp. Rxf. I have. 0462450906D0 . That's 12 digits what do you have
Anyway Glad your on the right track now!!
Old Jan 7, 2014 | 01:57 AM
  #63
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
If this might help.
Old Jan 7, 2014 | 04:19 PM
  #64
andysam's Avatar
andysam
does scangauge alert you automatically if there is an issue? For example, it would be nice if you could program it to beep if oil pressure got below a certain psi. I know the truck has stock gauges for this, but I have heard that by the time the stock light comes on, it is too late to prevent damage.
Does scangauge do this? Is there a product that does this?
Old Jan 7, 2014 | 04:37 PM
  #65
npccpartsman's Avatar
npccpartsman
SGII doesn't but IIRC Edge Insight has alarms.
Old Jan 7, 2014 | 04:45 PM
  #66
Rusty Axlerod's Avatar
Rusty Axlerod
DashBoss does also if you're living the iLife (Apple product owner).
Old Jan 7, 2014 | 05:05 PM
  #67
andysam's Avatar
andysam
Which is better at diagnosing problems, Dashboss or Scangauge? I assume Dashboss allows you to easily record stats to your iphone (duh) and computer. Does Scangauge allow you to send stats to your iphone or computer?
Basically, with the scangauge would I go to the truck and write down what it states? What about historical data?
Old Jan 11, 2014 | 09:53 AM
  #68
Frankiea87's Avatar
Frankiea87
For the codes i found online it didnt have any zeros infront of them...now is there anywhere online where it tells you what the correct (average) readings should be?
Old Jan 11, 2014 | 10:02 AM
  #69
Fal-308-Win
Yes, search for a thread titled " Engine Operating Values " by Pilot. There's a pdf file you can down load and print. Tim
Old Jan 11, 2014 | 10:15 AM
  #70
npccpartsman
Here's the table
File Type: pdf
Old Jan 11, 2014 | 10:28 AM
  #71
Rusty Axlerod
While both devices will display the values of almost any sensor on your truck, the DashBoss does a better job of retrieving codes. It also provides connectivity for e-mailing reports, displays more gauges, and is expandable with add-on sensors for pressures and EGT, and is easier to set up. If you have an iOS device already it's the winner in my opinion.
What the Scangauge brings to the table is simplicity. Once set up it just hangs out in the truck and comes on when you crank. No need to get out your phone and fire up an app and verify it connected etc. Many people here speak Scangauge also. Again, ScanGauge a cool little device that can serve you well but for power and convenience the DashBoss is better.
wm110106
Jan 21, 2016 09:26 AM
stang70
Aug 25, 2011 11:13 AM
gui88ford
Sep 8, 2010 07:47 AM
Smokin'
Apr 10, 2010 09:11 AM
