hey guys i have a 2005 6.0 F250, i recently have been doing some work to it including egr,ipr,oil cooler, FICM repair with atlas 40 tune, Anyways im looking into buying a scangauge, anyone recommend one certain one over an other? i see a bunch of people have the ScanGauge II.
If you want it fast. Walk into an Autozone and you should be able to get one.
If you want for less then ordering online should save some cash.
If you want pre-programmed I think you can get it here ScanGauge II Digital Data Monitor
Sean
What do you meen pre-programmed? Thought it was"
plug and play" ?
The SG2, is plug-n-play.
But, YOU have to enter a number of special X-codes to be able to read the unique sensors to the 6.0 PSD.
It's easy, and there are several youtube videos for those that need it.
I don't plan to keep my surface pro2, or smartphone sitting there as I drive so the SG2 is ideal for 90+% of the time.
Then having a Bluetooth to ODB2 adapter and one of the smartphone/PC applications to look when needed is something you can add later.
In a few places.
BLADE35 has a good list and some of the others also have a copy.
You can also look on the SGII site with that link I gave. You want
to look for the Ford 6.0 about half way down this page Ford/Lincoln/Mercury Specific : Linear Logic : Home of the ScanGauge
You will find a bunch. Just do a search on the FOrums for the SGII
Xgauge programming and you should find it.
Hey guys workin on enterig the xgauge codes...i put the ficm FMP code in and on the diplay its reading 120 , did i enter code wrong? Need change a setting?
Check reading again. Is it 12.0 volts? ??? There's three FICM gauges, logic power= 12/14 v, main power= 47/48.5 v, vehicle power =12/14 v
Theres no decimal pt...but even the. It should
Be at 48v- i jus got ficm repaired and working good...also showing battery voltage at 2.68 (brand new batteries last week)
