UVCH problem?
Old Dec 23, 2013 | 04:41 PM
Fraalan's Avatar
Fraalan
UVCH problem?
I have a late 2003 F250 with a 7.3.
factory built in october 2002.
I always assumed the UVCH was resolved before mine was built but you never know.
I have the following codes.
P0683 - this code has has been lingering around for a while
p1211
p1280
It just runs terrible, stalls, makes me miss meetings etc.
when it cools down it seems to run better for a short while.
Thanks for any imput.
The IPR was replaced a few months ago, i pulled the cover off of it and it was pretty oily.
Thanks for any input.
Alan
Old Dec 23, 2013 | 05:03 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
You replaced the ipr or the icp?
Old Dec 23, 2013 | 05:16 PM
Fraalan's Avatar
Fraalan
IPR was replaced in August this year.
I pulled the ICP wires off and it was oily,
Old Dec 23, 2013 | 05:25 PM
ToMang07's Avatar
ToMang07
That's a sign your ICP is bad and needs to be replaced.
Unplug the ICP, start it, and see if it runs any better. If it does, that's your most likely culprit.
Also make sure the tin nut on the back or the IPR is on tight.
TKegs763
Sep 25, 2013 03:35 AM
ToMang07
20
May 30, 2012 11:38 PM
I bleed ford blue
Apr 22, 2012 06:37 PM
hanklin
Apr 7, 2012 07:19 PM
stptim
Oct 16, 2011 05:17 PM
