02 7.3 no gp
Old Oct 12, 2011 | 09:02 AM
stptim's Avatar
stptim
02 7.3 no gp
eed help solving problem 02 -7.3. Truck has. Been running rough lie a gas motert hitting n 6 cylinders. After while it'll smooth itself out. Now wont. Start and got two codes. Po2211 and po670 I believe that's the icp.,, is there something else that I need to check
Old Oct 12, 2011 | 09:23 AM
ToMang07's Avatar
ToMang07
P1211{2}
ICP Pressure Is Above/Below Desired, Faulty IPR Valve
P1211{1}{3}
ICP Pressure Uncontrollable, Pressure Above/Below Desired
P1670 is a IDM code.
Is the WTS (wait to start) light going on/off like normal? How long is it on for?
To test the ICP, unplug it checking the plug and wires for oil. Start the truck, if it runs better or there's oil it needs to be replaced.
It also could be the UVCH, but definitely check the ICP first. What did you use to pull codes?
Old Oct 12, 2011 | 09:24 AM
ToMang07's Avatar
ToMang07
Old Oct 12, 2011 | 10:20 AM
stptim's Avatar
stptim
Sorry that code was. P1670 got codes from super. Chïp programer the truck died on mÿ wife's la's
Week it will not start it doesn't even fire off?
Old Oct 12, 2011 | 10:28 AM
ToMang07's Avatar
ToMang07
In that case, it's an IDM code, pushing it more towards the UVCH.
Does the WTS light come on/off like normal? Get any smoke when trying to start?
Checked all your fuses?
Old Oct 12, 2011 | 11:27 PM
stptim's Avatar
stptim
Wts OK. fuels all good.unplug orchestra no start
no smoke, bingo must be no fuel. I check this at
The start. pump was working there was fuel at top.
All OK, not now took off return line all I get is bubbles
Took off subply line same thing I have no pressure. Im
Lacking fuel!
Old Oct 12, 2011 | 11:55 PM
BigAlsPSD's Avatar
BigAlsPSD
If you open the drain(Yellow lever) on the rear of the bowl and cycle the key do you get anything?
Old Oct 13, 2011 | 08:42 AM
stptim's Avatar
stptim
Yes I get fuel
Old Oct 15, 2011 | 05:32 PM
stptim's Avatar
stptim
Where does the oil level need to be in the HPOP for it to start
Old Oct 15, 2011 | 06:59 PM
timmyboy76's Avatar
timmyboy76
1/2-3/4in below the plug.
You check the #30 fuse?
might wanna look into this... Welcome to guzzle's In-tank Hutch Mod Web Page
Old Oct 16, 2011 | 12:24 PM
stptim's Avatar
stptim
What is the PCM? Feus is good HPOP is now where it need. To be trying to get volt meter
Old Oct 16, 2011 | 05:17 PM
stptim's Avatar
stptim
I got truck running I think it was a combination of a few things Clean my. Plugins connections filled
HPOP And make sure that the batteries were up it started rtght up.the idale is real low and it is running rough just like before but after a wh.ile it will smooth out and run fine. yes I did put a new fuel pump on
edo488
15
Aug 21, 2017 10:57 PM
Zagato78
29
Feb 5, 2017 10:12 PM
tidexp
23
Sep 9, 2012 08:37 PM
forhammer33
19
Apr 30, 2012 11:05 PM
