Double Trouble!
Old Dec 21, 2013 | 02:15 PM
Jmoen7's Avatar
Jmoen7
Double Trouble!
Brand new to the 6.0, and the 6.0 forum. Coming from the v10!
Just going to get into this quick. Truck doesn't want to crank over in the cold, even when plugged in. Batteries just won't do it.
Took a reading of 12.1v when off. When cranked over it drops to 11.2v and then after running for a while the alternator only gets it to 12.8v and once the truck is turned off, it's back down to 11.8v.. Is my alternator working fine? Are my batteries just needing a charge? Or is the alternator dead?
2nd issue, is the dreaded white smoke.. tapped a 'T' into the coolant overflow i think it is, like most people, to test my headgaskets. Only pushed to a max of 4 PSI, is it even possible to stay that low? I was romping on it pretty good because i don't have a trailer to pull. And then once i drove normal, it would drop down to 0 PSI again. Is this working normally, and my head gaskets are O.K?
Of course that would mean my egr/oil cooler are both done but hey, that's alot cheaper than gaskets and studs right now and im okay with that!
Old Dec 21, 2013 | 02:19 PM
jswartz84's Avatar
jswartz84
Have the batteries load tested and have the alternator tested as well. It sounds like the alternator is shot. Cranking on it too much will kill the FICM.
What year is the truck?
Possibility of the EGR cooler leaking. Pull the EGR valve and check for moisture in the bottom.
Old Dec 21, 2013 | 02:55 PM
Jmoen7's Avatar
Jmoen7
It's a 2005 F350, stock truck for all i know. Just pulled the EGR, nice and crusty dry in there for all i can tell.. That's confusing
Old Dec 21, 2013 | 03:05 PM
jswartz84's Avatar
jswartz84
Is it losing coolant?
Old Dec 21, 2013 | 03:11 PM
Jmoen7's Avatar
Jmoen7
I have only put about 300 KM on the truck since i just got it, from what i can tell it hasn't lost any coolant, it is over-full to most peoples standards though, when pressure released it is at the marked full line on the bottle, last owner ignored the sticker where the full line is almost an inch lower.
Old Dec 21, 2013 | 03:14 PM
Misky6.0's Avatar
Misky6.0
How can you have pressure when you open the cap, yet your gauge showed 0 psi while driving..
Maybe your "t" connections had a leak.
Sent from my Sprint PC36100 using IB AutoGroup
Old Dec 21, 2013 | 03:16 PM
Jmoen7's Avatar
Jmoen7
When i am driving, it only goes to 4 psi. It may not be 0, my gauge has a wide swing. But it reads well enough that it goes no where near even 10. It could very well have 1-2 psi left but the gauge isnt reading it with the 0-100 swing
Old Dec 21, 2013 | 03:43 PM
nighthawk285's Avatar
nighthawk285
Try using a gauge that only goes to 20/50....you might not be seeing everything since the gauge isn't sensitive enough. However, since it does get to 0, you're probably not seeing any cylinder pressure in there and your headgaskets are fine.
Have someone start it when you get the white smoke while you stand by the exhaust and smell it....if it smells sweet it's coolant, if it smells like fuel, it could also be an injector.
Old Dec 21, 2013 | 04:36 PM
Jmoen7's Avatar
Jmoen7
I had my boss smell it, who has had a failure on a 6.0 before, and told me it doesn't smell sweet, in his words, "It smells like regular diesel exhaust to me".
Wouldn't an injector cause the truck to run and/or start rough?
And to your tip about a smaller pressure gauge, even if my 0-100 isn't as sensitive, i do believe my head gaskets are fine because i could only push it as high as 4 PSI. I even tightened all my T joint clamps and re-did the test. Same result.
Old Dec 21, 2013 | 04:45 PM
nighthawk285
If you have an injector that's pushing too much fuel or leaking past on startup, yes it could make it run rough.
And yep, if you're at least not getting above 10, your HGs are probably ok.
Old Dec 21, 2013 | 04:48 PM
Jmoen7's Avatar
Jmoen7
Well if my head gaskets are okay, and its dry under my EGR valve that checks out.
The truck runs smooth as even, even in a cold start (Being -15 C right now) at both idle and highway speed so i can't see an injector...
I'm at a loss
Old Dec 21, 2013 | 04:58 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Brrr! -15 is pretty chilly, hell on batteries and oil. Might consider a battery heater. Are you sure the block heater is working? Could the smoke just be condensation in the exhaust? Been awhile since I've seen those kind of temps.
Old Dec 21, 2013 | 05:05 PM
Jmoen7's Avatar
Jmoen7
Smoke can't be just condensation, it pours out too much on highway for me to be comfortable. Even after fully warmed up. New oil is needed right away though, that's for sure
Old Dec 21, 2013 | 05:09 PM
Rusty Axlerod
If it's not condensation, and the coolant level isn't dropping, seems it would have to be fuel? I'd try bubble test in tech folder. It may not catch one that's sticking intermittently but a leaker will likely show.
Old Dec 21, 2013 | 05:19 PM
9228.bobcat's Avatar
9228.bobcat
I would just start with the batteries first then altenator then when that checks out check the ficm volts.
