Double Trouble!
Old Dec 24, 2013 | 12:34 PM
  #31
9228.bobcat's Avatar
9228.bobcat
Originally Posted by Jmoen7
Even though this is my first diesel, i can tell what would be condensation and what's just white smoke, rolling down the highway if i step on it, it will spit white smoke until you let off the fuel. Exhaust is still stock because it's in the midst of being safetied after some ball joint work.
I did pull my EGR valve twice now, both times has been dry and crusty inside.
Only good thing i can say so far is it started in -41C without being plugged in yesterday
Mine does the same thing when its that cold, I'm telling you.
Old Dec 24, 2013 | 12:35 PM
  #32
Jmoen7's Avatar
Jmoen7
That i have not done, if i'm to get my butt outside, what am i looking for when i pull the cat?
Old Dec 24, 2013 | 12:36 PM
  #33
ryhed's Avatar
ryhed
mine smokes like crazy when it's cold out, so is every other diesel I see. Condensation. Jets leave a similar trail in the sky.
  #34
Jmoen7's Avatar
Jmoen7
Cold would be fine to me, but when it's fully warmed up it still does this
Old Dec 24, 2013 | 12:40 PM
  #35
9228.bobcat
Mine steams at fully warm too. Im telling you your tripping on nothing. You probably could just tap the cat with a hammer and see if it sounds hollow. Screw taking it off in -40
Old Dec 24, 2013 | 12:43 PM
  #36
BLADE35's Avatar
BLADE35
pull the down pipe off turbo back check for OIL
Old Dec 24, 2013 | 12:46 PM
  #37
BLADE35's Avatar
BLADE35
So Injector OR Boost issue
Low Boost will cause over fuel symtoms
May just have leaky inject pintail
If it starts to pour white smoke tow it
Old Dec 24, 2013 | 12:47 PM
  #38
9228.bobcat
Hey Benny, your in utah. Its cold there isnt it? Does your truck steam alot in the extreme cold?? Dang I forgot, you're broke down. Lol. Just messin with you.
Old Dec 24, 2013 | 12:48 PM
  #39
nighthawk285's Avatar
nighthawk285
Good call, hadn't thought of the turbo seal, though that's usually a pretty distinct blue.
I think we're getting somewhere....
Old Dec 24, 2013 | 12:49 PM
  #40
Jmoen7's Avatar
Jmoen7
Tripping out over nothing is much better than having to do a delete in the cold :P
Just getting answers from you knowledgeable people!
There's diesels all over the place here that i refer my own exhaust too and nothing is as much as what mines pouring out. If i could put a video to show i would, it just doesn't make sense to me that's all
Old Dec 24, 2013 | 12:52 PM
  #41
Jmoen7's Avatar
Jmoen7
Boost pushes to 23, smoke is not a noticeable blue, definitely white but not totally embarassing amounts of it or anything.
Is 23 normal boost?
My injector plugs are under the covers correct?
Old Dec 24, 2013 | 12:53 PM
  #42
9228.bobcat
Make a video of it and put on you tube. How long have you owned it?
Old Dec 24, 2013 | 01:01 PM
  #43
Jmoen7's Avatar
Jmoen7
i guess i will have to, i'll report back probably within the hour or 2 so no one go anywhere!
I'll check the turbo downpipe out before i do the video aswell and report on that too.
Old Dec 24, 2013 | 01:15 PM
  #44
ryhed's Avatar
ryhed
Trippin! Mine smoked for 22hrs from wyoming to missouri. I had just bought it, I tripped out too.
Old Dec 24, 2013 | 01:18 PM
  #45
9228.bobcat
What part of missouri?
