IPR removal write up
Old Dec 21, 2013 | 06:44 PM
  #31
F350-6's Avatar
F350-6
Before you go spending any money, I'd second unplugging the ICP. Then try swapping the IPR solenoid for the old one. Then try swapping the old IPR back in (switch the solenoid back first, then try the old IPR with the new solenoid). Then try applying 12volts to the IPR manually and see if it starts.
Old Dec 21, 2013 | 07:11 PM
  #32
HKusp's Avatar
HKusp
Will do Chris. Thanks for trying to help.
Old Dec 27, 2013 | 09:52 AM
  #33
Tact's Avatar
Tact
Jason.....did you resolve your issues?
Old Dec 27, 2013 | 07:31 PM
  #34
HKusp's Avatar
HKusp
No, not yet. I am going to fool around with it tomorrow. I am going to pull the ICP sensor and pressurize the oil rail and see if I have an o-ring leaking pressure. I have a sneaking suspicion that there is an injector that has come loose.
67nukeford
Sep 24, 2009 07:55 AM
Tom D
May 5, 2007 11:02 AM
lostin90s
Jul 15, 2006 01:52 PM
bigbluebronco
Paint & Bodywork
Apr 9, 2004 03:02 PM
Sixoh
15
Mar 16, 2004 09:22 AM
