Rusted in cotter pins.
Old Sep 22, 2009 | 08:40 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I'm trying to get the front suspension off of my 67, but these damn cotter pins are rusted in their holes. Any one have an idea of how to get them out?
Old Sep 22, 2009 | 11:10 AM
jowilker's Avatar
jowilker
If you can break it off, try driving a nail or punch on the end of it to force it out.
John
Old Sep 22, 2009 | 11:28 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
I have one that just completly came apart, but I can get all of it out. It's in a terrible spot, I may just have to split the nut.
Old Sep 22, 2009 | 11:42 AM
75F350's Avatar
75F350
I typically remove or cut both ends that stick out through the castle nut. Once the nut can clear the pin, or whatever is left inside, I can remove the nut while some of the piece is till inside of the hole. This allows me to remove the part and work on it in a more controlled environment.
If Intend to replace the part that I am removing, I just remove as much of the pin as possible and then lean on my 1/2" impact. My gun makes quick work of stubborn fasteners like this, and usually sheer the cotter pins right off. Usually ruins the nut and even the Tie rod end, but if I plan on a replacement anyway, it is no loss.
Once in a while I also use a drill to clear the broken keys out of the holes, but sometimes a drill just does not fit where I am working.
Old Sep 22, 2009 | 12:18 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
The ones I'm having problems with are on the trailing arms on the front differential. I don't want to trash the threads on the arm, and I will probably get new castle nuts for it. It's in a tight spot, that's why I'm having a problem getting it out. I might try to see if I can drill them out, I'll have to get the looped side cleard out, since that is the side I have access to.
Old Sep 22, 2009 | 12:44 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by 75F350
...sheer the cotter pins right off.
Usually ruins the nut and even the Tie rod end...
That's not been my experience with shearing off cotter pins. :/
Maybe it's from the speed from the power tool ruining the bolt and nut,
since I have never used power tools for nuts? {shrug}
"9 inch Klein line pliers" :)
Large dikes would be a (better?) substitute to get a pin started moving.
Squeeze together or break off the split ends first then grip the head and
using leverage, pull on it just to move it a little. If it won't move with that
method and cuts the head off instead, then shear what's left -a little-,
kinda careful like, then back the nut up and remove the pieces.
They also sell a "bent, heavy duty scratch awl" for pulling cotter pins.
I have more luck with my line-pliers but the "cotter pin puller" is a real
useful tool to have for lots of other things so it isn't a waste of money
if it doesn't work for this job.
The radius arm nut isn't all that hard to get to so only the rust is really
messing with you. Right? Wrong?
Alvin in AZ
ps- Retired railroad signalape here, check out the cotter pins on some
switch points sometime LOL :) Almost all of them were re-used in the old
days and the line pliers and the top of the rail were handy to re-straighten
cotter pins, done thousands of 'm, no kidding. :)
Old Sep 22, 2009 | 12:51 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Yep, the pins are rusted in solid. I tried using a heavy awl to get them out, just bent the awl! Not enough sticking out to grab with the pliers either.
Old Sep 24, 2009 | 07:55 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Well, managed to get them out. Broke off as much of the pin that I could, and just drilled out the rest.
3twinridges
May 21, 2017 12:25 PM
Boomer89
Sep 26, 2016 06:33 PM
Pridnjoy
Nov 29, 2015 11:39 PM
rebar13
May 28, 2013 09:30 PM
Talyn
22
Aug 27, 2011 11:54 PM
