proper pin removal?
Old Jul 15, 2006 | 10:21 AM
lostin90s's Avatar
lostin90s
proper pin removal?
Would like to know correct way to remove pins from wire couplers. I know I read how to do it on a post but can't find it. Do you need a special tool or thanks.
Old Jul 15, 2006 | 12:32 PM
westtntrucker's Avatar
westtntrucker
You can get a special tool for the job, but i have also found a good sturdy sewing needle with the tip ground a little will do the same. In the front of the plug, there will be a small notch above the pin. push needle in slightly and then pull wire gently.
Old Jul 15, 2006 | 01:18 PM
EPNCSU2006's Avatar
EPNCSU2006
Most likely you will have to remove a pin retainer first, which is usually red. I have found that a flathead glasses or jeweler's screwdriver works well too. Make sure to take the retainer out because you won't get anywhere with that still in the connector.
Old Jul 15, 2006 | 01:27 PM
MustangGT221's Avatar
MustangGT221
I use those tiny screwdrivers like Eric said...works like a charm.
Old Jul 15, 2006 | 01:52 PM
lostin90s's Avatar
lostin90s
Thanks guys just thought I'd ask before I broke something. ( I'm good at destruction)
