Possible turbo issue
Old Dec 10, 2013 | 01:00 PM
  #106
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by FordTruckEnthusaist
Sorry, what is the ref.?
PCM sends a 5 volt reference to the sensor and expects a certain voltage back.
Josh
Old Dec 10, 2013 | 01:06 PM
  #107
FordTruckEnthusaist's Avatar
FordTruckEnthusaist
Alright, well I won't have access to that fancy scan tool for a while as tomorrow is my last day of class for the semester. So how does one do this with a DMM?
Old Dec 10, 2013 | 02:49 PM
  #108
npccpartsman's Avatar
npccpartsman
Take the sensor connector off, ground one end of the DMM and probe the three plugs inside the connector with the key on. You should get 5V in one of them. IIRC it's the "odd man" inside the connector (two of them are side by side).
Old Dec 10, 2013 | 02:59 PM
  #109
FordTruckEnthusaist
Okay I'll give that a shot tomorrow. Voltmeter just on regular 12V right?
Sure do appreciate y'all's help, this thread may be 87 pages long by the end of it but I'm going to figure out what's wrong haha.
Old Dec 10, 2013 | 03:04 PM
  #110
Bullitt390's Avatar
Bullitt390
Easier to leave the connector connected to the sensor and Backprobe each wire with KOEO.
You're looking for the 5 volt vref and the return signal to the PCM
Josh
Old Dec 10, 2013 | 03:31 PM
  #111
FordTruckEnthusaist
Would you have to pull out all the wires to do that? Or can you just cut the shrink tubing open enough to get a probe to touch wire?
Old Dec 10, 2013 | 04:24 PM
  #112
Bullitt390's Avatar
Bullitt390
Use a pushpin to insert into the back of the connector. Do not cut the insulation.
Josh
Old Dec 10, 2013 | 04:35 PM
  #113
Rusty Axlerod's Avatar
Rusty Axlerod
Here is a nice wiring diagram:
https://www.ford-trucks.com/ford-man...%20diagram.pdf
Old Dec 10, 2013 | 05:17 PM
  #114
FordTruckEnthusaist
Originally Posted by Rusty Axlerod
Holy ****.
So you can't just pull the connector out of the sensor, flip it upside down and test the 3 pins? I thoughts that what you were talking about earlier but now I'm confused haha.
Old Dec 10, 2013 | 08:38 PM
  #115
npccpartsman
Holy ****.
That's a good diagram to store on your computer. It's not extremely specific AFA wire colors go but it will help you go a long way with diagnostics and how things work with each other in a general sort of way.
You can disconnect it at the sensor but their may be a reason for testing it connected to the sensor. That I don't know.....
Old Dec 10, 2013 | 08:50 PM
  #116
Bullitt390's Avatar
Bullitt390
With the connector disconnected you only have the 5 volt vref. Back probing with sensor connected verifies the 5 volt reference and also the sensor signal to the PCM.
If you have those two things, it shows:
1) the sensor works
2) the problem lies between the sensor output and PCM.
Which means start chasing the harness for chafing or breaks/corrosion.
Not to throw salt in the wounds, but for the 8 pages it's taken to do this would take about 15 minutes with a competent mechanic in the field.
Josh
Old Dec 10, 2013 | 10:44 PM
  #117
FordTruckEnthusaist
Well good thing I'm not a mechanic making money off this then I guess. I just don't always understand things completely by reading it, I have to physically see it and do it. Not just related to mechanical, I just have to actually do it for it to click and I'm not about to pay somebody to do something that I can figure out haha
2006fordf25060
Jan 17, 2018 07:47 AM
trevorrules
Nov 9, 2015 11:51 AM
9228.bobcat
Aug 5, 2012 03:24 PM
Duksrule
Oct 15, 2008 05:37 PM
brabe
Nov 15, 2003 12:41 AM
