turbo cleaning question
Old Aug 5, 2012 | 10:20 AM
9228.bobcat's Avatar
9228.bobcat
I got a 07 turbo from someone and when I got it apart there was oil in and around the unison ring. Looked Like it just leaked when I tipped it upside down. Is there any way oil can get in there when you tip it one whay or another? There was no shaft play at all.
Old Aug 5, 2012 | 01:56 PM
Mich6.0's Avatar
Mich6.0
It seals under pressure from the turbo side I believe mine did the same thing when I took it apart If it still leaks there is seal kit available Tousley Ford has great price and are a sponsor just mention FTE for the discount
Old Aug 5, 2012 | 02:30 PM
9228.bobcat
Unhappy
I was thinking of that as well. I went ahead and threw it on real quick and it works good. Not blowing any smoke.I think all is well other than an a exhaust leak around my turbo and y pipe.
Old Aug 5, 2012 | 03:24 PM
Mich6.0's Avatar
Mich6.0
leave your turbo loose and put some anti seize on the inside of the clamps, it will help them slide into position and they won't stick when you have tear into it again. Then tighten down the bolts to the turbo.
green_95
Mar 7, 2016 01:56 AM
Muddy 13
Jun 20, 2011 06:29 AM
Dbailey
Mar 24, 2010 07:38 PM
nutfarmii
Jun 9, 2009 06:17 PM
OldRed460
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Feb 1, 2006 02:19 AM
