I thought I posted this earlier but looking back I see that I didn't.. I do have a 4" turbo back, wouldn't that drop the back pressure?
Not to your extent and the other two sensors won't affect EBP at KOEO. EBP should be a bit higher than MAP at idle. I find it kind of strange that you get a very small reading.
I scanned through quickly and didn't see what you were using to read your parameters with......
Another test is to use some air and pressure up the sensors (MAP and EBP) to see if they respond.
I guess I don't understand how you're supposed to get 14PSI +\- KOEO, how does it build back pressure without running?
But anyways, what do I need to do to get this thing within spec? Replace the connector?
Basically the MAP, EBP, and BARO are calibrated to read atmospheric pressure at KOEO which is ~ 14.4 at sea level. All 3 sensors should read within 1.5 psi of each other at KOEO. That's an easy test to see if you have a bad sensor, wire, connector, etc. Since your EBP is reading 0 at KOEO there is a problem there somewhere.
Yesterday before I replaced the sensor I unplugged the sensor then started it to see what happened, and it was reading like 37 psi at idle, the turbo also sounded really weird I didn't dare drive it. I'm using the Edge Insight CTS to monitor.
I thought it was 14.7 at sea level? Which is correlating with pure octanes stoichiometric ratio .
I have an Insight CTS too. I just went outside to my 2003. I live at about 950ft elevation in NH.
It has been plugged in but it's still a cold engine (104*) .... and I don't believe I have any driveability issues so here's what I got off my truck ...
